6 Replies Latest reply on Sep 7, 2014 11:22 PM by Laubender
    How can i insert the insertion point in each paragraph first
    NithinMNK
      Hi all
      Please find the below script, this script place the insertion point in end of the each paragraph, but i need to place the insertion point in first letter of the each paragraph. Please help.
      var myDoc=app.documents.item(0)
      var myLib=app.libraries.item(0)
      app.findTextPreferences=null;
      app.changeTextPreferences=null;
      app.findChangeTextOptions.caseSensitive=false;
      app.findChangeTextOptions.includeFootnotes=false;
      app.findTextPreferences.appliedParagraphStyle="TX"
      app.findTextPreferences.findWhat="^p"
      var myFinds=myDoc.findText()
      for(i=0; i<myFinds.length; i++)
      var myIcon=myLib.assets.item("Para").placeAsset(myFinds[i].insertionPoints[0])[0]
      myIcon.appliedObjectStyle=myDoc.objectStyles.item("Para No")
      Thanks & Regards
      Nithin
        • 1. Re: How can i insert the insertion point in each paragraph first
          Sajeev Sridharan Level 4
          Try Grep,
          app.findGrepPreferences=app.changeGrepPreferences=null;
          app.findGrepPreferences.findWhat=".+\\r"
          app.findGrepPreferences.appliedParagraphStyle="TX"
          var myFinds=myDoc.findGrep()
              myFinds[i].select();
              myFinds[i].insertionPoints[0].select();
          Vandy
          • 2. Re: How can i insert the insertion point in each paragraph first
            Chinnadk Level 4
            Hi Nithin,
            Try this,
            var doc = app.activeDocument,
                myLib=app.libraries.item(0),
                _paragraphs = doc.stories.everyItem().paragraphs.everyItem().getElements(), i;
            for(i =_paragraphs.length-1;i>=0;i--)
                    if(_paragraphs[i].appliedParagraphStyle.name == "TX")
                            var myIcon=myLib.assets.item("Para").placeAsset(_paragraphs[i].insertionPoints[0])[0];
                            myIcon.appliedObjectStyle=doc.objectStyles.item("Para No")
            Regards,
            Chinna
            • 3. Re: How can i insert the insertion point in each paragraph first
              NithinMNK Level 1
              Hi Vandy
              Thanks for your help, if am using the script, the anchor object is placed in First paragraph in first and the other paragraphs in end of the line. Find below the screenshot.
              For your kind information, am using the below script:
              app.findGrepPreferences=null;
              app.findChangeGrepOptions.includeFootnotes=false;
              Please help me.
              Thanks & Regards
              Nithin
              • 4. Re: How can i insert the insertion point in each paragraph first
                Could you please show me the input and output clearly in a screenshot
                Vandy
                • 5. Re: How can i insert the insertion point in each paragraph first
                  Chinnadk Level 4
                  After inserting the first item, the insertion points of the remaining item have shifted so use reverse loop or try my above script .
                  • 6. Re: Re: How can i insert the insertion point in each paragraph first
                    @Nithin – inserting the anchor by placing the asset is changing the position of the next anchor, because the script's for-loop is running from the first found instance to the last found one.
                    If you go through all the found instances from back to forth would be one solution.
                    for(i=myFinds.length-1; i>=0; i--)
                    Another one would be doing the search from back to forth and not changing the for-loop:
                    var myFinds=myDoc.findGrep(true);
                    Array of Text findGrep ([reverseOrder: bool])
                    Finds text that matches the find what value.
                    Uwe
