3 Replies Latest reply on Sep 8, 2014 3:21 PM by rundenk
    Document units don't match program settings?
    rundenk
      My vertical units and horizontal units are different in Indesign even though in the settings they are both set to millimetres.
      When i open a new document and set margins the vertical units are in centimetres and horizontal are in mIllimetres. In my settings i have all my units set at millimetres and it doesn't seem to affect the setting for when i open a new doc.
      This is frustrating because my tool palette units are different too. I would rather they be all one setting
        • 1. Re: Document units don't match program settings?
          @rundenk – what do you see in the preferences, if you restart InDesign with no documents open?
          All settings set to millimeters?
          If not, adjust them as you wish and quit InDesign. That should reset the preference file of InDesign.
          The next time when you add a new document, the settings should be as you want them.
          What can go wrong?
          InDesign is alerting you that it unexpectedly quit after you quit the app. That would possibly mean InDesign cannot overwrite the old preference settings…
          The preference settings are "corrupt". And you have to remove the settings in your file system.
          Read/Write permission problems for your preference settings file in the file system.
          … ?? Maybe other problems with the new synching feature n case you are using InDesign CC-2014 ?
          Uwe
          • 2. Re: Document units don't match program settings?
            rundenk Level 1
            Fixed.
            I thought I had done that but obviously not.
            I cant say i fully understand the syncing features either but no doubt that's for another thread.
            cheers
            • 3. Re: Document units don't match program settings?
              rundenk Level 1
              i did as you inferred.
              Reopened indesign and check the settings. They were set at MM and CM. Obviously everytime i had tried to change the settings I had a document open
