1. Re: MpjSingleSource Error publishing from FM12 in TC5 to webhelp
moszapy1 Sep 12, 2014 2:10 AM (in response to Paperless2k)Did you try with fresh small document ?
2. Re: MpjSingleSource Error publishing from FM12 in TC5 to webhelp
Paperless2k Sep 15, 2014 12:50 AM (in response to moszapy1)Thanks for your question.
Yes. I published as a Responisive HTML5 first and that worked fine.
I have reduced the document to a two file book consisting of 12 pages when pdf'd and that works fine in HTML5. Note that this is a small document in our terms. The original document was 100+ pages which is still small by our terms.
When I try the WebHelp publish the error comes up when the feedback says it is loading settings.
3. Re: MpjSingleSource Error publishing from FM12 in TC5 to webhelp
moszapy1 Sep 15, 2014 2:14 AM (in response to Paperless2k)To sum up, you can generate Responsive HTML5 but not WebHelp with same document ?
4. Re: MpjSingleSource Error publishing from FM12 in TC5 to webhelp
Paperless2k Sep 15, 2014 2:16 AM (in response to moszapy1)Exactly right.
5. Re: MpjSingleSource Error publishing from FM12 in TC5 to webhelp
moszapy1 Sep 15, 2014 3:09 AM (in response to Paperless2k)We are unable to repro it. This can be document specific.Can you please share your small document with us. You can upload it to dropbox and share the link with mdsameer87@gmail.com
Mohd Sameer
Adobe RH team.
6. Re: MpjSingleSource Error publishing from FM12 in TC5 to webhelp
moszapy1 Sep 15, 2014 3:11 AM (in response to Paperless2k)Also please share your setting file(sts).
Thanks.
