4 Replies Latest reply on Sep 9, 2014 7:31 AM by Szalam
    Puppet pins
    Arrakis Level 1
      IS there a way to keep the puppet pins visible when the layer is not selected?   Im attaching nulls to them but I can't see where to place the null when I cant see the pins.
        • 1. Re: Puppet pins
          You could copy and paste the pin locations to the nulls' position to be perfectly accurate without any guesswork at all.
          • 2. Re: Puppet pins
            Arrakis Level 1
            Good idea thanks.    Do you know how to parent a layer to a pre comp that has duik bones?  When I move the bones I want the child layer to move with the deformation but can't figure out how to do this. At the moment it just stays put while the parent bends etc.
            • 3. Re: Puppet pins
              Arrakis Level 1
              Ok so I thought this was a good idea but when I tried paste the position of the puppets to the nulls they are in a different position??
              • 4. Re: Puppet pins
                Are you saying the top left of the nulls aren't aligning with the puppet
                pins?
                If they're not aligning, are your nulls parented to the layer with the
                puppet pins applied? They'll need to be for this to work if the layer has
                been moved or scaled at all.
