1. Re: MasterThemeSchema.xml file has invalid data error when customizing layout
Peter Grainge Sep 10, 2014 5:33 AM (in response to norapetch) -
2. Re: MasterThemeSchema.xml file has invalid data error when customizing layout
Peter Grainge Sep 10, 2014 5:35 AM (in response to Peter Grainge)Are you sure you have selected a responsive layout rather than a multiscreen layout?
3. Re: MasterThemeSchema.xml file has invalid data error when customizing layout
norapetch Sep 10, 2014 5:40 AM (in response to Peter Grainge)Yes. I found someone else with the problem and Adobe suggested not working with files over the network, so I'll give that a try. That's a disappointing response because in our work environment, we do not store files locally (for backups, accessibility, etc.) so I'll have to copy everything to the network.
4. Re: MasterThemeSchema.xml file has invalid data error when customizing layout
Peter Grainge Sep 10, 2014 5:49 AM (in response to norapetch)Has not working over the network fixed the problem? If it has, check both ways again to establish beyond doubt that it is a problem with working on the network. If it does prove to be that, please file a bug but also post back here.
Please follow this link to report a bug.
http://www.Adobe.com/cfusion/mmform/index.cfm?name=wishform&product=38
5. Re: MasterThemeSchema.xml file has invalid data error when customizing layout
norapetch Sep 10, 2014 8:29 AM (in response to Peter Grainge)I had some time to play with it this morning and working from the network does seem to cause the issue. I found that you have to click Save in the Responsive HTML Properties window (e.g, go to customize, make a change, click Save, click Save again) for the error to happen. Following the same steps, I do not get the error when working from my desktop. Bug submitted; thanks for the link.
6. Re: MasterThemeSchema.xml file has invalid data error when customizing layout
Willam van Weelden Sep 11, 2014 8:04 AM (in response to norapetch)For anyone reading this thread with problems on the MasterThemeSchema.xml, I created a XSD to help you find problems in the XML file. You can get the XSD from: https://www.dropbox.com/s/yfqnqdvx5u8cdgx/MasterThemeSchema.xsd?dl=0
Kind regards,
Willam
