9 Replies Latest reply: Sep 9, 2014 8:51 AM by Lilybiri RSS
    show good answer
    Annemieke_vdB Community Member
      Hi there,
      I just made a quiz with 5 questions. When I check the questions in previewmode, this funny thing happens:
      when I click on the right answer, I don't get feedback
      when I click on the wrong answer, I get the wrong feedback.
      when do I get the feedback for the right answer? I cannot find anything in properties.
      who can help me?
      Annemieke
        • 1. Re: show good answer
          Lilybiri CommunityMVP
          'annemieke' = Flemish?
          Which version do you use? You seem to have deleted the Correct Caption. If you tell me the version, will show you a screenshot where to find it. It is not in the Properties panel but in the Quiz Properties panel.
          • 2. Re: show good answer
            HI,
            almost, its dutch. :-) And thanks for your quick reply!
            These are the properties I used. The weird thing is that it looks like I have the same properties at a different question where it does work.
            Annemieke
            • 3. Re: show good answer
              Hoe heb je dit getest? Er bestaat de mogelijkheid dat net deze vraag corrupt is. Kan je proberen om een identieke vraag te maken (je kan de 'lange' teksten' wel kopiëren/plakken).
              Check also the corresponding master slide, hoping you didn't delete the original Correct caption.
              • 4. Re: show good answer
                I've tested it with F11. I also show you the screen recording I made.
                The master slide is okay, if I press the button ' reset master slide', everything stays intact.
                in the video you can see that the third question doesn't give feedback
                can a question be corrupt? I've 3 out of 5 question that are corrupt in that case...
                • 5. Re: show good answer
                  Can I see a screenshot of the master slide, because your mentioning that 3 out of 5 questions are corrupt really points to the master slide. Do you see the correct caption there?
                  • 6. Re: show good answer
                    in dutch: bedoel je met correct caption, het juist aangevinkte antwoord?
                    dit is in ieder geval een screenshot:
                    • 7. Re: show good answer
                      Oops, ik bekeek daarnet nog even de eerste screenshot: waarom heb je zowel de actie On Success als die On Failure op 'No action' gezet? Normaal staat die op 'Continue', en je zou die ook kunnen wijzigen naar 'Go to Next Slide'. Beide acties worden uitgevoerd als tweede stap bij het Submit proces. Ik vraag me echt af of die wijziging naar No Action, wat betekent dat er niets moet gebeuren de oorzaak zou kunnen zijn. Je wenst toch niet dat de gebruiker blijft kamperen op de dia?
                      Ik vermoed een probleem met het verstaan van de betekenis van Indienen (Submit) en 'Verder' (Next). Normaal heb je Verder niet nodig tijdens de quiz, enkel tijdens de Review. De Submit button (Indienen) is de knop die het hele proces in de hand houdt, de twee stappen, die ik beschreef in dit artikel: Question Question Slides in Captivate - Captivate blog
                      Je zal merken dat ik aanbeveel om de Verder knop te slepen onder de Indienen knop, zodat er geen verwarring ontstaat bij de gebruiker. Tijdens een 'Review' is er geen Indienen knop, en komt de Verder knop automatisch te voorschijn.
                      Lilybiri
                      • 8. Re: show good answer
                        Hoi Lilibery,
                        Fijn dat je zo meedenkt. Het was inderdaad overbodig.
                        Ik krijg alleen nog steeds geen feedback als ik mijn antwoord goed heb. Waar kan dat aan liggen?
                        Groetjes,
                        Annemieke
                        • 9. Re: show good answer
                          Beetje aan het eind van mijn Latijn, master slide ziet er OK uit, ik zie de Correct and Failure captions, zoals het hoort. Als je zeker bent dat je het juiste antwoord hebt aangeduid als correct zou dit moeten werken. En ik heb al heel wat onderzoek verricht naar quiz slides zoals je aan mijn blog kan merken.
                          Kan je een blank project creëren en één van de slecht werkende vragen reproduceren? Gebruik hetzelfde thema met dezelfde master slides.
