SQL Error Help
Max Resnikoff Sep 9, 2014 6:45 AMHi,
I have been making forms to insert data into my database. I have had no trouble with the past 3, but this one keeps giving me an error. They are all exactly the same, and I have even retried remaking the page and table in the database, but no luck.
This is the error:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'condition, image, notes, location, tagnumber) VALUES ('sdf', 'sdf', 'Shirt', 'sd' at line 1
Here is my table code:
-- phpMyAdmin SQL Dump
-- version 3.5.5
-- Host: localhost
-- Generation Time: Sep 09, 2014 at 08:41 AM
-- Server version: 5.5.39-36.0
-- PHP Version: 5.4.23
SET SQL_MODE="NO_AUTO_VALUE_ON_ZERO";
SET time_zone = "+00:00";
/*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */;
/*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */;
/*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */;
/*!40101 SET NAMES utf8 */;
-- Database: `mresnik_dramadatabase`
-- Table structure for table `costume`
CREATE TABLE IF NOT EXISTS `costume` (
`id` int(11) NOT NULL AUTO_INCREMENT,
`name` text NOT NULL,
`description` text NOT NULL,
`type` text NOT NULL,
`material` text NOT NULL,
`size` text NOT NULL,
`gender` text NOT NULL,
`colour` text NOT NULL,
`timeperiod` text NOT NULL,
`accessories` text NOT NULL,
`value` text NOT NULL,
`condition` text NOT NULL,
`image` text NOT NULL,
`notes` text NOT NULL,
`location` text NOT NULL,
`tagnumber` int(50) NOT NULL,
`datecreated` timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP,
PRIMARY KEY (`id`)
) ENGINE=InnoDB DEFAULT CHARSET=utf8 AUTO_INCREMENT=1 ;
/*!40101 SET CHARACTER_SET_CLIENT=@OLD_CHARACTER_SET_CLIENT */;
/*!40101 SET CHARACTER_SET_RESULTS=@OLD_CHARACTER_SET_RESULTS */;
/*!40101 SET COLLATION_CONNECTION=@OLD_COLLATION_CONNECTION */;
And here is my page code where the form is:
<?php require_once('Connections/drama_database.php'); ?>
<?php
if (!function_exists("GetSQLValueString")) {
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
if (PHP_VERSION < 6) {
$theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
switch ($theType) {
case "text":
$theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
break;
case "long":
case "int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
break;
case "double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
break;
case "date":
break;
case "defined":
$theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
break;
return $theValue;
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form1")) {
$insertSQL = sprintf("INSERT INTO costume (name, `description`, type, material, `size`, gender, colour, timeperiod, accessories, `value`, condition, image, notes, location, tagnumber) VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s)",
GetSQLValueString($_POST['name'], "text"),
GetSQLValueString($_POST['description'], "text"),
GetSQLValueString($_POST['type'], "text"),
GetSQLValueString($_POST['material'], "text"),
GetSQLValueString($_POST['size'], "text"),
GetSQLValueString($_POST['gender'], "text"),
GetSQLValueString($_POST['colour'], "text"),
GetSQLValueString($_POST['timeperiod'], "text"),
GetSQLValueString($_POST['accessories'], "text"),
GetSQLValueString($_POST['value'], "text"),
GetSQLValueString($_POST['condition'], "text"),
GetSQLValueString($_POST['image'], "text"),
GetSQLValueString($_POST['notes'], "text"),
GetSQLValueString($_POST['location'], "text"),
GetSQLValueString($_POST['tag'], "text"));
mysql_select_db($database_drama_database, $drama_database);
$Result1 = mysql_query($insertSQL, $drama_database) or die(mysql_error());
$insertGoTo = "costumeinventory.php";
$insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
$insertGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s", $insertGoTo));
$query_cosadd = "SELECT * FROM costume";
$cosadd = mysql_query($query_cosadd, $drama_database) or die(mysql_error());
$row_cosadd = mysql_fetch_assoc($cosadd);
$totalRows_cosadd = mysql_num_rows($cosadd);
<html>
<title>Add Costume</title>
</html>
<?php session_start(); ?>
<!--HEADER CONTENT START -->
<script src="SpryAssets/SpryValidationTextField.js" type="text/javascript"></script>
<script src="SpryAssets/SpryValidationTextarea.js" type="text/javascript"></script>
<script src="SpryAssets/SpryValidationSelect.js" type="text/javascript"></script>
<head>
<link href="stylesheet.css" rel="stylesheet" type="text/css">
<link href="SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css">
</head>
</html>
<style type="text/css">
body{ margin:0px; background:#FFF;}
.header {
height:165px;
background:#FFF;
border:1px solid#CCC;
position:fixed;
width:100%;
top:0px;
</style>
</head>
<div class="header"><?php include('defaultheader.php');?></div>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<!--HEADER CONTENT END -->
<div align="center">
<h1>Add New Costume</h1>
</div>
<form name="form1" method="POST" action="<?php echo $editFormAction; ?>">
<table width="350" border="0">
<tr>
<td width="118" class="formtag">Name</td>
<td width="222"><span id="sprytextfield1">
<label for="name"></label>
<input name="name" type="text" class="formfield" id="name">
<span class="textfieldRequiredMsg">A value is required.</span></span></td>
</tr>
<tr>
<td class="formtag">Description</td>
<td><span id="sprytextfield2">
<label for="description"></label>
<textarea name="description" class="formfielddesc" id="description"></textarea>
</tr>
<tr>
<td class="formtag">Type</td>
<td><label for="type"></label>
<select name="type" class="formfield" id="type">
<!--Connection to Other Table-->
<option id="0">-- Select Type --</option>
<?php
require("Connections/drama_database.php");
$getallcostumetype = mysql_query("SELECT * FROM costumetype");
while($viewallcostumetype = mysql_fetch_array($getallcostumetype)){
<option id="<?php echo $viewallcostumetype['id']; ?>"><?php echo $viewallcostumetype['type'] ?></option>
<?php } ?>
</select></td>
</tr>
<tr>
<td class="formtag">Material/Fabric</td>
<td><span id="sprytextfield3">
<label for="material"></label>
<input name="material" type="text" class="formfield" id="material">
</tr>
<tr>
<td class="formtag">Size</td>
<td><label for="size"></label>
<select name="size" class="formfield" id="size">
<option id="0">-- Select Size --</option>
<?php
$getallcostumesize = mysql_query("SELECT * FROM costumesize");
while($viewallcostumesize = mysql_fetch_array($getallcostumesize)){
<option id="<?php echo $viewallcostumesize['id']; ?>"><?php echo $viewallcostumesize['size'] ?></option>
<?php } ?>
</select></td>
</tr>
<tr>
<td class="formtag">Gender</td>
<td><label for="gender"></label>
<select name="gender" class="formfield" id="gender">
<option id="0">-- Select Gender --</option>
<?php
$getallcostumegender = mysql_query("SELECT * FROM costumegender");
while($viewallcostumegender = mysql_fetch_array($getallcostumegender)){
<option id="<?php echo $viewallcostumegender['id']; ?>"><?php echo $viewallcostumegender['gender'] ?></option>
<?php } ?>
</select></td>
</tr>
<tr>
<td class="formtag">Colour/Pattern</td>
<td><span id="sprytextfield4">
<label for="colour"></label>
<input name="colour" type="text" class="formfield" id="colour">
</tr>
<tr>
<td class="formtag">Timeperiod</td>
<td><span id="sprytextfield5">
<label for="timeperiod"></label>
<input name="timeperiod" type="text" class="formfield" id="timeperiod">
</tr>
<tr>
<td class="formtag">Accessories</td>
<td><span id="sprytextfield6">
<label for="accessories"></label>
<textarea name="accessories" class="formfielddesc" id="accessories"></textarea>
</tr>
<tr>
<td class="formtag">Value</td>
<td><label for="value"></label>
<select name="value" class="formfield" id="value">
<option id="0">-- Select Value --</option>
<?php
$getallcostumevalue = mysql_query("SELECT * FROM costumevalue");
while($viewallcostumevalue = mysql_fetch_array($getallcostumevalue)){
<option id="<?php echo $viewallcostumevalue['id']; ?>"><?php echo $viewallcostumevalue['value'] ?></option>
<?php } ?>
</select></td>
</tr>
<tr>
<td class="formtag">Condition</td>
<td><label for="condition"></label>
<select name="condition" class="formfield" id="condition">
<option id="0">-- Select Condition --</option>
<?php
$getallcostumecondition = mysql_query("SELECT * FROM costumecondition");
while($viewallcostumecondition = mysql_fetch_array($getallcostumecondition)){
<option id="<?php echo $viewallcostumecondition['id']; ?>"><?php echo $viewallcostumecondition['condition'] ?></option>
<?php } ?>
</select></td>
</tr>
<tr>
<td class="formtag">Image</td>
<td><span id="sprytextfield7">
<label for="image"></label>
<input name="image" type="text" class="formfield" id="image">
</tr>
<tr>
<td class="formtag">Notes</td>
<td><span id="sprytextfield8">
<label for="notes"></label>
<textarea name="notes" class="formfielddesc" id="notes"></textarea>
</tr>
<tr>
<td class="formtag">Location</td>
<td><label for="location"></label>
<select name="location" class="formfield" id="location">
<option id="0">-- Select Location --</option>
<?php
$getallcostumelocation = mysql_query("SELECT * FROM costumelocation");
while($viewallcostumelocation = mysql_fetch_array($getallcostumelocation)){
<option id="<?php echo $viewallcostumelocation['id']; ?>"><?php echo $viewallcostumelocation['location'] ?></option>
<?php } ?>
</select></td>
</tr>
<tr>
<td class="formtag">Tag Number</td>
<td><span id="sprytextfield9">
<label for="tag"></label>
<input name="tag" type="text" class="formfield" id="tag">
</tr>
<tr>
<td> </td>
<td> </td>
</tr>
<tr>
<td colspan="2" align="center"><input name="addcos" type="submit" class="button" id="addcos" value="Add Costume"></td>
</tr>
</table>
<input type="hidden" name="MM_insert" value="form1">
</form>
</div>
<?php
mysql_free_result($cosadd);
var sprytextfield1 = new Spry.Widget.ValidationTextField("sprytextfield1");
var sprytextfield2 = new Spry.Widget.ValidationTextField("sprytextfield2");
var sprytextfield3 = new Spry.Widget.ValidationTextField("sprytextfield3");
var sprytextfield4 = new Spry.Widget.ValidationTextField("sprytextfield4");
var sprytextfield5 = new Spry.Widget.ValidationTextField("sprytextfield5");
var sprytextfield6 = new Spry.Widget.ValidationTextField("sprytextfield6");
var sprytextfield7 = new Spry.Widget.ValidationTextField("sprytextfield7");
var sprytextfield8 = new Spry.Widget.ValidationTextField("sprytextfield8");
var sprytextfield9 = new Spry.Widget.ValidationTextField("sprytextfield9");
</script>
