0 Replies Latest reply on Apr 10, 2007 9:34 PM by Kasem_Abotel
    URL Parameters are not passed to the Application
    Kasem_Abotel
      Hi
      I want to read url parameters
      the Application has 'parameters' variable, however the only this I get is
      historyUrl=history.htm
      lconid=<some Number>
      if I pass anything else I do not get it
      I checked the html generated and it has the following line
      AC_FL_RunContent(
      "src", "xSA",
      "width", "100%",
      "height", "100%",
      "align", "middle",
      "id", "xSA",
      "quality", "high",
      "bgcolor", "#869ca7",
      "name", "xSA",
      "flashvars",'historyUrl=history.htm%3F&lconid=' + lc_id + '',
      "allowScriptAccess","sameDomain",
      "type", "application/x-shockwave-flash",
      "pluginspage", " http://www.adobe.com/go/getflashplayer"
      can I instruct the compiler when generating the HTML template to pass all the parameters coming from the URL
      or the only option I have is to generate this template myself passing the URL params via Java Script
      do you guys have any java script code to pass the param
      any help is appreciated
      Kasem
