1 Reply Latest reply on Sep 9, 2014 1:55 PM by Willi Adelberger
    How can I change the software language?
      I have InDesign CC, Photoshop CC and Illustrator CC. While Illustrator is in the English version InDesign and Photoshop is in Norwegian. I would like all the programs to be in English.
      How can I change the language to English?!
        • 1. Re: How can I change the software language?
          If your system is in Norwegian and you want InDesign to operate in English you will have to uninstall it. Use the Uninstaller from Adobe. On the Mac (you did not mentions your OS) the uninstaller is found in the Utilities Folder in the Program Folder. If your system language is English, you can install it above your Norwegian installation. InDesign will use the same language as the OS has if it is installed, otherwise it will take what is installed. (There are some OS tools available which will force a program to start with a selected language.)
          When you have to install you English version do following:
          1. Go to the Creative Cloud Application, on the Mac you will find it on the top in the menu stripe, on Windows down. It has a symbol of 2 cc building a .
          2. In its menu you see a gear symbol, select it and choose preferences
          3. In the App tab select your wanted language.
