8 Replies Latest reply on Nov 2, 2014 2:27 PM by Muffet
    Lighting effects is missing the circles to adjust?
    ChronicDK
      Hey, everybody
      I am currently working on a project, where I need to use the Lighting Effects option. However, when I enter the Lighting Effects rendering, I am not provided with the circles, which allows me to change the lighting to my likeness (see screenshot). Where has my circles gone?
      Thank you for your help.
      Best regards,
      Jesper
        • 1. Re: Lighting effects is missing the circles to adjust?
          I suspect it may have to do with your OS and Displays Device Driver.  If you use Photoshop menu Help>System Info... and use its copy key and then past the info here it may help resolve you problem.
          Supply pertinent information for quicker answers
          The more information you supply about your situation, the better equipped other community members will be to answer. Consider including the following in your question:
          • Adobe product and version number
          • Operating system and version number
          • The full text of any error message(s)
          • What you were doing when the problem occurred
          • Screenshots of the problem
          • Computer hardware, such as CPU; GPU; amount of RAM; etc.
          • 2. Re: Lighting effects is missing the circles to adjust?
            ChronicDK Level 1
            Alrighty A looooooot of text, but here it goes...
            Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64
            Operating System: Mac OS 10.9.4
            System architecture: Intel CPU Family:6, Model:42, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
            Physical processor count: 4
            Processor speed: 2500 MHz
            Built-in memory: 6144 MB
            Free memory: 2621 MB
            Memory available to Photoshop: 5175 MB
            Memory used by Photoshop: 70 %
            Image tile size: 1024K
            Image cache levels: 4
            OpenGL Drawing: Enabled.
            OpenGL Drawing Mode: Advanced
            OpenGL Allow Normal Mode: True.
            OpenGL Allow Advanced Mode: True.
            OpenGL Allow Old GPUs: Not Detected.
            OpenGL Version: 2.1 ATI-1.24.35
            OpenCL Version:
            Video Card Vendor: ATI Technologies Inc.
            Video Card Renderer: ATI Radeon HD 6750M OpenGL Engine
            Display: 2
            Display Depth:= 32
            Display Bounds:=  top: 0, left: -1920, bottom: 1080, right: 0
            Video Renderer ID: 16915206
            Video Card Memory: 489 MB
            Video Rect Texture Size: 16384
            OpenCL Version: 1.2 (Jun  3 2014 12:43:41)
            Display: 1
            Main Display
            Display Depth:= 32
            Display Bounds:=  top: 0, left: 0, bottom: 1080, right: 1920
            Serial number: 92299702664043361605
            Application folder: Macintosh HD:Applications:Adobe Photoshop CS6:
            Photoshop scratch has async I/O enabled
            Scratch volume(s):
              Startup, 465,0G, 111,3G free
            Required Plug-ins folder: Macintosh HD:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
            Primary Plug-ins folder: Macintosh HD:Applications:Adobe Photoshop CS6:Plug-ins:
            Additional Plug-ins folder: not set
            Installed components:
               adbeape.framework   adbeape   3.3.8.19346   66.1025012
               AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
               adobe_caps.framework   adobe_caps   6.0.29.0   1.276181
               AdobeACE.framework   AdobeACE   2.19.18.19243   66.492997
               AdobeAGM.framework   AdobeAGM   4.26.17.19243   66.492997
               AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
               AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
               AdobeBIB.framework   AdobeBIB   1.2.02.19243   66.492997
               AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.492997
               AdobeCoolType.framework   AdobeCoolType   5.10.31.19243   66.492997
               AdobeCrashReporter.framework   AdobeCrashReporter   6.0.20120201
               AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
               AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
               AdobeLinguistic.framework      17206
               AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
               AdobeOwl.framework   AdobeOwl   4.0.93   66.496052
               AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
               AdobePDFSettings.framework   AdobePDFSettings   1.4
               AdobePIP.framework   AdobePIP   6.0.0.1654
               AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
               AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
               AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
               AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
               AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
               ahclient.framework   ahclient   1.7.0.56
               aif_core.framework   AdobeAIF   3.0.00   62.490293
               aif_ocl.framework   AdobeAIF   3.0.00   62.490293
               aif_ogl.framework   AdobeAIF   3.0.00   62.490293
               AlignmentLib.framework   xcode   1.0.0.1
               amtlib.framework   amtlib   6.0.0.75
               boost_date_time.framework   boost_date_time   6.0.0.0
               boost_signals.framework   boost_signals   6.0.0.0
               boost_system.framework   boost_system   6.0.0.0
               boost_threads.framework   boost_threads   6.0.0.0
               Cg.framework   NVIDIA Cg
               CIT.framework   CIT   2.0.5.19287   145486
               data_flow.framework   AdobeAIF   3.0.00   62.490293
               dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
               dvacore.framework   dvacore   6.0.0.0
               dvamarshal.framework   dvamarshal   6.0.0.0
               dvamediatypes.framework   dvamediatypes   6.0.0.0
               dvaplayer.framework   dvaplayer   6.0.0.0
               dvatransport.framework   dvatransport   6.0.0.0
               dvaunittesting.framework   dvaunittesting   6.0.0.0
               dynamiclink.framework   dynamiclink   6.0.0.0
               FileInfo.framework   FileInfo   66.145433   66.145433
               filter_graph.framework   AdobeAIF   3.0.00   62.490293
               hydra_filters.framework   AdobeAIF   3.0.00   62.490293
               ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
               ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
               image_compiler.framework   AdobeAIF   3.0.00   62.490293
               image_flow.framework   AdobeAIF   3.0.00   62.490293
               image_runtime.framework   AdobeAIF   3.0.00   62.490293
               LogSession.framework   LogSession   2.1.2.1652
               mediacoreif.framework   mediacoreif   6.0.0.0
               PlugPlug.framework   PlugPlug   3.0.0.383
               UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
               wrservices.framework
            Required plug-ins:
               Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
               ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc.  All rights reserved. - from the file “AdobeADM.bundle”
               Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Average 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
               Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Camera Raw 7.0 (308), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
               Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Cineon 13.0 20120315.r.428 2012/03/15:21:00:00  ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
               Clouds 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
               Collada DAE 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
               Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Crop and Straighten Photos 13.0 20120315.r.428 2012/03/15:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
               Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Difference Clouds 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
               Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Eazel Acquire 13.0 20120315.r.428 2012/03/15:21:00:00  ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
               Embed Watermark NO VERSION - from the file “DigiSign.plugin”
               Enable Async I/O 13.0 20120315.r.428 2012/03/15:21:00:00  © 2004-2012 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
               Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               FastCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
               Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
               IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               JPEG 2000 13.0 20120315.r.428 2012/03/15:21:00:00  ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
               Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
               Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
               Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
               Matlab Operation 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
               Measurement Core 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
               Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               MMXCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
               Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Multiprocessor Support 13.0 20120315.r.428 2012/03/15:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
               Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               NTSC Colors 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
               Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
               OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               PCX 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
               Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Photoshop 3D Engine 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
               Picture Package Filter 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
               Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Pixar 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
               Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Portable Bit Map 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
               Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Radiance 13.0 20120315.r.428 2012/03/15:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
               Read Watermark NO VERSION - from the file “DigiRead.plugin”
               Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
               ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
               Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Solarize 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
               Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
               Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Wireless Bitmap 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
               ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
            Optional and third party plug-ins: NONE
            Plug-ins that failed to load: NONE
            Flash:
               Mini Bridge
               Kuler
            Installed TWAIN devices: NONE
            • 3. Re: Lighting effects is missing the circles to adjust?
              I don't use a Mac so I know little about Mac OS versions and which drivers you should have installed for the  ATI  6750M chip-set in your laptop.  The first thing you should do is update your CS6.  The current Mac version of CS6 is version 13.0.6 yours is at version 13.0 your missing all the CS6 updates.  CS6 is the buggiest version of Photoshop ever released by adobe. Without the CS6 updated CS6 is unstable and has many problems.  Adobe Blog stated that first CS6 update which was released 5 months after CS6 was corrected 506 core issues in CS6
              • 4. Re: Lighting effects is missing the circles to adjust?
                ChronicDK Level 1
                Update solved the problem. Thanks a bunch
                • 5. Re: Lighting effects is missing the circles to adjust?
                  Muffet
                  Hi JJMack, I am having the same problem as the person who originally asked the question. I am on version 13.0.6 and I do not have the circles to adjust the light.  Do you happen to know what I can do to solve this issue?  Thanks!
                  • 6. Re: Lighting effects is missing the circles to adjust?
                    You have the updates for Mac CS6 do you also have the latest video drivers installed.  Use menu Help>System Info  the copy and past the information here. I do not use a Mac I do not know how the get the latest drivers for Mac Apple may want to control whats software is on your mac.
                    • 7. Re: Lighting effects is missing the circles to adjust?
                      Muffet Level 1
                      It looks like I may have two video cards?  I have also gone into PS and tried different settings in preferences.
                      Intel HD Graphics 4000:
                        Chipset Model: Intel HD Graphics 4000
                        Type: GPU
                        Bus: Built-In
                        VRAM (Total): 512 MB
                        Vendor: Intel (0x8086)
                        Device ID: 0x0166
                        Revision ID: 0x0009
                        gMux Version: 3.2.19 [3.2.8]
                      NVIDIA GeForce GT 650M:
                        Chipset Model: NVIDIA GeForce GT 650M
                        Type: GPU
                        Bus: PCIe
                        PCIe Lane Width: x8
                        VRAM (Total): 1024 MB
                        Vendor: NVIDIA (0x10de)
                        Device ID: 0x0fd5
                        Revision ID: 0x00a2
                        ROM Revision: 3688
                        Displays:
                      Color LCD:
                        Display Type: LCD
                        Resolution: 2880 X 1800
                        Retina: Yes
                        Pixel Depth: 32-Bit Color (ARGB8888)
                        Main Display: Yes
                        Mirror: Off
                        Online: Yes
                        Built-In: Yes
                        Connection Type: DisplayPort
                      CE240W:
                        Resolution: 1920 x 1200
                        Display Serial Number: 28743047
                        Mirror: Off
                        Online: Yes
                        Rotation: Supported
                        Adapter Type: Apple Mini DisplayPort To VGA Adapter
                        Adapter Firmware Version: 1.03
