1. Re: cpQuizInfoAnswerChoice not storing the value
Lilybiri Sep 9, 2014 10:50 PM (in response to Sreekanth_S)Do not get rid of the default Submit button, it is an essential component
of quiz slides. You can change its look in object style manager, on the
master slides but you have to keep it. Eventually you can give it a fill
and stroke with opacity 0, and put an image of your choice under it (it
wiil always have priority in the stack, be on top). You should have looked
at my post about Question Question slides as well. Need to write a book
about ball those rules
2. Re: cpQuizInfoAnswerChoice not storing the value
Sreekanth_S Sep 10, 2014 4:28 AM (in response to Lilybiri)Thanks Lilybiri. I am testing this again with the default Submit button. Now, the cpQuizInfoAnswerChoice (and hence the associated custom variable) picks up the option number instead of the actual value of the option. Here is the screenshot that explains it better.
How do I get the actual values?
Sreekanth
3. Re: cpQuizInfoAnswerChoice not storing the value
Lilybiri Sep 10, 2014 5:14 AM (in response to Sreekanth_S)The system quizzing variables store a content like it is transferred to the LMS, and for cpQuizInfoAnswerChoice that is the way...only the numbers of the chosen answer will be transmitted. If you want the content of the answers, you'll have to create a conditional action.
