2 Replies Latest reply on Sep 16, 2014 3:29 AM by mdegamo
    Formatting text into styles
    VeluVK
      I need to find all formatting text into character styles, i used the below code. it's working fine.
      app.findTextPreferences = app.changeTextPreferences = null;
      app.findTextPreferences.fontStyle = "Bold"
      app.changeTextPreferences.appliedCharacterStyle = "bold";
      app.documents.item(0).changeText();
      app.findTextPreferences.fontStyle = "Italic"
      app.changeTextPreferences.appliedCharacterStyle = "italic";
      app.findTextPreferences.fontStyle = "Bold Italic"
      app.changeTextPreferences.appliedCharacterStyle = "bolditalic";
      app.findTextPreferences.underline=true;
      app.changeTextPreferences.appliedCharacterStyle = "underline";
      app.findTextPreferences=app.changeTextPreferences=null;
      alert("Characer Styles are applied for all Font styles")
      Incase (Bold, Italic, Bold italic) + underline text comes, it will not work. so i created the character styles for boldwithunderline, italicwithunderline, bolditalicwithunderline.
      Can you anyone please include the below condition?
      Bold = "bold"
      Italic = "italic"
      Bold Italic = "bolditalic"
      Normal text + underline = "underline"
      Bold + underline = "boldunderline"
      Italic + underline = "italicunderline"
      Bold Italic + underline = "bolditalicunderline"
      Is the below code is correct? if not please suggest.
      if((app.findTextPreferences.fontStyle = "Bold") &&  (app.findTextPreferences.underline=true) == true)
      app.changeTextPreferences.appliedCharacterStyle = "boldunderline";
      else if((app.findTextPreferences.fontStyle = "Italic") &&  (app.findTextPreferences.underline=true) == true)
      app.changeTextPreferences.appliedCharacterStyle = "italicunderline";
      else if((app.findTextPreferences.fontStyle = "Bold Italic") &&  (app.findTextPreferences.underline=true) == true)
      app.changeTextPreferences.appliedCharacterStyle = "bolditalicunderline";
      Regards,
      Velu
        • 1. Re: Formatting text into styles
          Sajeev Sridharan Level 4
          Try this,
          //for bold underline formatting
          Your first code is correct, just do some minor changes
          Vandy
          • 2. Re: Formatting text into styles
            mdegamo Level 1
            You have to list all possible properties and toggle each on/off for every instance.
            You can have an array of objects to handle the mapping record.
            Example:
            var mapper = [
                      charStyle: 'bold-italic-underline',
                      props: {
                           fontStyle: 'Bold Italic',
                           underline: true
                      charStyle: 'bold-italic',
                      props: {
                           underline: false
            // Then use the above collection to filter the search
            for (var i = 0, l = mapper.length; i < l; i += 1) {
                 for (var prop in mapper[i].props) {
                      if (app.findTextPreferences.hasOwnProperty(prop)) {
                           app.findTextPreferences[prop] = mapper[i].props[prop];
                 app.changeTextPreferences.appliedCharacterStyle = mapper[i].charStyle;
