Problem: Always when i copy fields (no matter which), acrobat names the new one like that: name#1, which connects them together, meaning the content of both fields is always the same = Bad thing.
This copy method is the fastest way to arrange fields which should not be aligned. Therefore I need acrobat to name the new fields like it does when you use the "create multipe duplicates" (dont know the english translation of this command). Because then it names the new ones without #, which makes them seperate and independent fields.
Short: How can i disable the automatic "#" labeling of new fields?
OR: How can i disconnect EXISTING fields which were named with "#"?
Thx for help
Erik
The "#" is the widget number for any field with the same name. You would have to rename the fields. Another option would be to use the template object and spawn an overlay and then move the fields as needed.
