35 Replies Latest reply: Nov 7, 2014 11:41 AM by ajcampa RSS
    ERROR ITMS-9000: "No .app bundles found in the package"]
    ajcampa Community Member
      I've been trying to upload my ipa generating Flash Builder using the Application Loader, unsuccessfully, more than a month.
      I tried to generate all certificates again and I have not gotten results.
      The error is "ERROR ITMS-9000:" No .app bundles found in the package "]" attached image for if you think of anything to anyone. Any help will be very welcome.
      I have also tried to unzip the ipa file, access the Payload folder and compress .app inside.
      Does anyone have idea what can it be?
      If you need anything more than information only have to ask me.
        • 1. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
          Colin Holgate CommunityMVP
          Which version of Application Loader are you using?
          • 2. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
            • 3. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
              nobody can help me?
              • 4. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                Anton Azarov Community Member
                Don't do this. Adobe AIR SDK generate IPA that must be uploaded without repacking.
                About No .app bundles found in the package - problems may be different. Starting from incorrect certificate/provisioning profile and finishing many things... you need show us steps that you done so we can find solution.
                • 5. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                  Mark.fromOP Community Member
                  If you are building from the PC there has been a change in how the app is uploaded. Originally you would create the .ipa file send that to your Mac, rename the .ipa to .zip unzip it and zip the payload folder inside but a couple months back Apple changed how the file is delivered now you follow the first couple of steps. Create the .ipa file from flash, email it to yourself on a Mac then rename the .ipa to .zip and upload that. It might be the issue with your file try it both ways to see if it helps anything.
                  • 6. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                    IPA from PC can be uploaded directly without any re-zipping.
                    • 7. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                      I'll have to try that next time but it also works as a .zip.
                      • 8. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                        2 weeks ago our client manually done this Receive IPA from me and upload it using application loader without re-zipping
                        • 9. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                          It did used to be, long ago, that you would have to take the APP out of the payload folder and zip that, and upload the zip file. But for the last year I just directly select the IPA file that Flash Pro made.
                          • 10. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                            I say the steps that I do:
                            1º I make the production certificate .cer in developer.apple.com
                            2º Impor this certificate in the kayChain and I export the .p12
                            3º I make the distribution Provisioning Profile
                            4º In the flex builder, I click in "Export Release Build..." and I select the previous certificates (.p12 and Provisioning Profile)
                            5º Add the ANEs libs (i have three differents ANEs)
                            6º Finish to Export and .ipa is created.
                            Nothing else....
                            I have to say, I updated the version of AIR to the 14. One ANE needed.
                            Any idea? .Please help
                            • 11. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                              I can put screenshots of each of the steps... if you need it
                              • 12. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                                Are you selecting "For Apple App Store" or something similar to that line because there is a few release builds like AdHoc.
                                • 13. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                                  I select, in the "Export Realise Build...",
                                  is this ok no?
                                  • 14. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                                    The distribution provisioning profile can be either Ad Hoc or App Store. Are you sure that the one you're using is App Store?
                                    That aside, there have been App Store submission issues fixed in AIR 15, in particular the current beta, 15.0.0.274. Make sure you're using that one.
                                    • 15. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                                      When you make the provioning profile, AdHoc and AppStore, is the same options... is that right?
                                      • 16. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                                        That's the certificate, that you made the P12 from, and yes, it's the same certificate for Ad Hoc or App Store. I was referring to the provisioning profile, there's one for Ad Hoc and one for App Store. When you make those you also select the certificate that the profile uses. And in the case of Ad Hoc you can also set what devices it will work on.
                                        So, if you can remember selecting which devices the profile should work on, it's certainly not an App Store provisioning profile! If you can remember not being able to select devices, then it's the right kind.
                                        • 17. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                                          Yes, the provisioning profile, I select AppStore.
                                          • 18. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                                            So, which exact version of AIR are you using?
                                            • 19. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                                              Before to continue, thank you very much for help me.
                                              I can see.... 14.0 sdk version
                                              • 21. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                                                I tested this version, and the result is similar:
                                                I created all the certificates again.
                                                I tried on a new computer.
                                                And... nothing
                                                Any idea?
                                                • 22. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                                                  I need help, please. I don't know what to do now
                                                  If someone needs my project for to view what is the problem, please, you tell me and i send this for private message.
                                                  I tested, making a new project with different name. A new certs (mobile provision, p12 and app id) and the error it's there!!!
                                                  Please, please help.
                                                  "No .app bundle found in this package" if I try upload the .app rezip
                                                  "The IPA is invalid. It does not include Payload directory" if I try upload the .ipa
                                                  • 23. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                                                    Just thought of one thing, there have been problems in the past where the error was misleading, and the problem was some of the names that had been used.
                                                    What is the name of the app, and any other names in the XML? If there are any non-Roman characters in there it could lead to issue. Even accented characters may be a problem.
                                                    • 24. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                                                      Don't rezip IPA. You must know that Adobe AIR SDK generate IPA that must be uploaded directly without any further modifications.
                                                      • 25. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                                                        thanks for your answer, but in my XML I dont have any rare characters.. I checked
                                                        have you other idea?
                                                        • 26. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                                                          Just to check what Anton was asking, you do upload the IPA file, don't you? Not a re-zipped .app file. Also, could be worth trying Application Loader 3.0, although 2.9.1 should work.
                                                          • 27. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                                                            I only rezip for i try others options... If i dont rezip, dont work too.
                                                            I will try to upload the application Loader to 3.0 version. Thanks.
                                                            • 28. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
                                                              i updated the Application Loader, and now, when i select the ipa, show me the next message:
                                                              "the package not contain info.plist"
                                                              • 29. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
        How did you build the app?
        • 30. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
        i build all to generate the swf out in bin-debug folder. Then, i click in "project/export release build..." and i select the "export to folder:", the export as "Signed packages for each target platform", and i push in "next>". Then exporting release build, and show me, in a popup information "one o more warnings were found while buildend the release version. You may choose to ignore these warnings.". I see that it's a normal warnings, except, the next:
        "The style 'cornerRadius' is only supported by type 'mx.core.Container' with the theme 'halo, spark'"
        I click in ok button and i put the packaging settings and I click in Finish button.
        If i see the package, into Payload directory and into .app package, i find the info.plist file...
        • 31. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
        Your message seemed to end early. If you're using Flex, are you sure you have the right version of AIR SDK? If you're editing the info.plist, why are you doing that?
        • 32. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
        In my manifest file i can see the air versión 15.0
        I not edit the info.plist.
        If i open the info.plist, i can see the CTAirSdkVersion is 15.0.0.249
        • 33. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
        There are two versions of AIR 15, one for Flex, one for not Flex. Are you using the Flex one?
        • 34. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
        yes i am, in other case, i think that i show me other errors, if i remember well...
        • 35. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
        Any idea about the error "the package not contain info.plist"?? The error is with the Application Loader 3.0.
        Somebody use Flash Builder?
        • 36. Re: ERROR ITMS-9000: "No .app bundles found in the package"]
        I updated the Application Loader to 3.0 version. I have a new error. "The package does not contain info.plist".
        I searched in internet and i found that this error, is possible, it is for CFBundleVersion in info.plist. Is this possible?
        this is my app.xml
        <?xml version="1.0" encoding="utf-8" standalone="no"?>
        <application xmlns="http://ns.adobe.com/air/application/15.0">
        <!-- A universally unique application identifier. Must be unique across all AIR applications. -->
        <!-- Using a reverse DNS-style name as the id is recommended. (Eg. com.example.ExampleApplication.) Required. -->
        <id>com.xxx.XXX</id>
        <!-- Used as the filename for the application. Required. -->
        <filename>XXX</filename>
        <!-- The name that is displayed in the AIR application installer.  -->
        <!-- May have multiple values for each language. See samples or xsd schema file. Optional. -->
        <name>XXX</name>
        <!-- A string value of the format <0-999>.<0-999>.<0-999> that represents application version which can be used to check for application upgrade. -->
        <!-- Values can also be 1-part or 2-part. It is not necessary to have a 3-part value.-->
        <!-- An updated version of application must have a versionNumber value higher than the previous version. Required for namespace >= 2.5 . -->
        <versionNumber>1.1.1</versionNumber>
        <!-- A string value (such as "v1", "2.5", or "Alpha 1") that represents the version of the application, as it should be shown to users. Optional. -->
        <versionLabel>1.1.1</versionLabel>
        <!-- Description, displayed in the AIR application installer. -->
        <description>
        XXX
        </description>
        <!-- Copyright information. Optional -->
        <copyright>XXX 2014</copyright>
        <!-- Publisher ID. Used if you're updating an application created prior to 1.5.3 -->
        <!-- <publisherID></publisherID> -->
        <!-- Settings for the application's initial window. Required. -->
        <initialWindow>
        <!-- The main SWF or HTML file of the application. Required. -->
        <!-- Note: In Flash Builder, the SWF reference is set automatically. -->
        <content>[This value will be overwritten by Flash Builder in the output app.xml]</content>
        <!-- The title of the main window. Optional. -->
        <!-- <title></title> -->
        <!-- The type of system chrome to use (either "standard" or "none"). Optional. Default standard. -->
        <!-- <systemChrome></systemChrome> -->
        <!-- Whether the window is transparent. Only applicable when systemChrome is none. Optional. Default false. -->
        <!-- <transparent></transparent> -->
        <!-- Whether the window is initially visible. Optional. Default false. -->
        <visible>true</visible>
        <!-- Whether the user can minimize the window. Optional. Default true. -->
        <!-- <minimizable></minimizable> -->
        <!-- Whether the user can maximize the window. Optional. Default true. -->
        <!-- <maximizable></maximizable> -->
        <!-- Whether the user can resize the window. Optional. Default true. -->
        <!-- <resizable></resizable> -->
        <!-- The window's initial width in pixels. Optional. -->
        <!-- <width></width> -->
        <!-- The window's initial height in pixels. Optional. -->
        <!-- <height></height> -->
        <!-- The window's initial x position. Optional. -->
        <!-- <x></x> -->
        <!-- The window's initial y position. Optional. -->
        <!-- <y></y> -->
        <!-- The window's minimum size, specified as a width/height pair in pixels, such as "400 200". Optional. -->
        <!-- <minSize></minSize> -->
        <!-- The window's initial maximum size, specified as a width/height pair in pixels, such as "1600 1200". Optional. -->
        <!-- <maxSize></maxSize> -->
        <!-- The initial aspect ratio of the app when launched (either "portrait" or "landscape"). Optional. Mobile only. Default is the natural orientation of the device -->
        <!-- <aspectRatio></aspectRatio> -->
        <!-- Whether the app will begin auto-orienting on launch. Optional. Mobile only. Default false -->
        <autoOrients>true</autoOrients>
        <!-- Whether the app launches in full screen. Optional. Mobile only. Default false -->
        <fullScreen>true</fullScreen>
        <!-- The render mode for the app (either auto, cpu, gpu, or direct). Optional. Default auto -->
        <!-- <renderMode></renderMode> -->
        <!-- Whether or not to pan when a soft keyboard is raised or lowered (either "pan" or "none").  Optional.  Defaults "pan." -->
        <softKeyboardBehavior>none</softKeyboardBehavior>
        </initialWindow>
        <!-- We recommend omitting the supportedProfiles element, -->
        <!-- which in turn permits your application to be deployed to all -->
        <!-- devices supported by AIR. If you wish to restrict deployment -->
        <!-- (i.e., to only mobile devices) then add this element and list -->
        <!-- only the profiles which your application does support. -->
        <supportedProfiles>mobileDevice</supportedProfiles>
        <!-- Languages supported by application -->
        <!-- Only these languages can be specified -->
        <supportedLanguages>es</supportedLanguages>
        <icon>
        <image16x16>logo-XXX16x16.png</image16x16>
        <image29x29>logo-XXX29x29.png</image29x29>
        <image32x32>logo-XXX32x32.png</image32x32>
        <image36x36>logo-XXX36x36.png</image36x36>
        <image48x48>logo-XXX48x48.png</image48x48>
        <image50x50>logo-XXX50x50.png</image50x50>
        <image57x57>logo-XXX57x57.png</image57x57>
        <image58x58>logo-XXX58x58.png</image58x58>
        <image72x72>logo-XXX72x72.png</image72x72>
        <image76x76>logo-XXX76x76.png</image76x76>
        <image100x100>logo-XXX100x100.png</image100x100>
        <image114x114>logo-XXX114x114.png</image114x114>
        <image120x120>logo-XXX120x120.png</image120x120>
        <image128x128>logo-XXX128x128.png</image128x128>
        <image144x144>logo-XXX144x144.png</image144x144>
        <image152x152>logo-XXX152x152.png</image152x152>
        <image512x512>logo-XXX512x512.png</image512x512>
        <image1024x1024>logo-XXX1024x1024.png</image1024x1024>
        </icon>
        <iPhone>
        <InfoAdditions>
        <![CDATA[
        <key>UIDeviceFamily</key>
        <array>
        <string>1</string>
        <string>2</string>
        </array>
        <key>MinimumOSVersion</key>
        <string>6.1</string>
        <key>CFBundleURLTypes</key>
        <array>
        <dict>
        <key>CFBundleURLSchemes</key>
        <array>
        <string>xxxxxxxx</string>
        </array>
        </dict>
        </array>
        <key>FacebookAppID</key>
        <string>xxxxxxx</string>
        <key>UIRequiredDeviceCapabilities</key>
        <array>
        <string>gps</string>
        <string>camera-flash</string>
        </array>
        <key>UIRequiresPersistentWiFi</key>
        <string>NO</string>
        <key>UIBackgroundModes</key>
        <array>
        <string>location</string>
        </array>
        </InfoAdditions>
        <requestedDisplayResolution>standard</requestedDisplayResolution>
        </iPhone>
        <extensions>
        <extensionID>com.freshplanet.AirImagePicker</extensionID>
        <extensionID>com.freshplanet.AirFacebook</extensionID>
        <extensionID>com.freshplanet.AirAlert</extensionID>
        </extensions>
        </application>
