1. Re: Height of the HTML banner in the Library Tab
mham187 Sep 10, 2014 10:10 AM (in response to Another1984)Did you use the store configurator as base of your modification or did you take an example from the Devnet-pages? (http://www.adobe.com/devnet/digitalpublishingsuite/custom-storefronts-and-libraries.html)
2. Re: Height of the HTML banner in the Library Tab
Another1984 Sep 10, 2014 2:15 PM (in response to mham187)Hi mham187,
Thank you for your answer.
No, I started completely from scratch.
But everything works fine in my code.
The problem is that I can't set desired height of the banner in the standard library tab.
3. Re: Height of the HTML banner in the Library Tab
Lohrii Alo Sep 10, 2014 8:21 PM (in response to Another1984) -
4. Re: Height of the HTML banner in the Library Tab
Exood Sep 12, 2014 2:01 AM (in response to Lohrii Alo)Lohrii Alo, you're wrong. The description in App builder (and in documentation) is also wrong. You can specify any height but it cannot exceed 40% of library's height. For example, if you set the height for iphone's to be fixed 250px the results will be: 227px on 4" iPhone and 192 on 3,5" iPhone = these are max for smartphones.
5. Re: Height of the HTML banner in the Library Tab
Another1984 Sep 12, 2014 2:04 AM (in response to Exood)Hi Exood, thank you for your answer!
6. Re: Height of the HTML banner in the Library Tab
Exood Sep 12, 2014 2:07 AM (in response to Another1984)You're welcome. And please keep in mind, that if you set height that exceeds 40% of library's height, the actual height on iPads will be different in lanscape and portrait.
7. Re: Height of the HTML banner in the Library Tab
Another1984 Sep 12, 2014 2:13 AM (in response to Exood)Yes, exactly. But we locked orientation in vertical mode.
Thank you
