1. Re: Changing stroke [reduction] thickness of a font (Glyph)?
Obi-wan Kenobi Sep 10, 2014 1:17 PM (in response to shawninvancouver)Hi,
Screenshot, please!
2. Re: Changing stroke [reduction] thickness of a font (Glyph)?
SRiegel Sep 10, 2014 1:27 PM (in response to shawninvancouver) -
3. Re: Changing stroke [reduction] thickness of a font (Glyph)?
shawninvancouver Sep 10, 2014 1:36 PM (in response to SRiegel)Hello SRiegel,
I actually began looking for a thinner character. Thanks for saving me a lot of time.
But for purely academic knowledge, it would be nice to know how to reduce the thickness of a font's character. I'm thinking that I would have to reduce the character to curves... or rather create outlines. After converting to outlines, I still cannot find a way to 'thin' out the font (or outline). Reducing its Width, just flattens out the outline... not what I am looking for.
Any thoughts?
5. Re: Changing stroke [reduction] thickness of a font (Glyph)?
shawninvancouver Sep 10, 2014 1:39 PM (in response to Obi-wan Kenobi)Hello Obi-wan Kenobi,
I just want the character to be thinner. So imagine the bracket, uploaded by SRiegel, being 1 pixel thick, rather than about four pixels thick. That is what I am trying to accomplish.
6. Re: Changing stroke [reduction] thickness of a font (Glyph)?
SRiegel Sep 10, 2014 1:42 PM (in response to shawninvancouver)There are options, like adding a white stroke, or taking it into illustrator and using a negative offset path, but IMO, none of these produce great results, because the resulting form lacks the visual balance of a font that was designed from the start to be thin.
8. Re: Changing stroke [reduction] thickness of a font (Glyph)?
shawninvancouver Sep 10, 2014 1:57 PM (in response to Obi-wan Kenobi)I don't have Helvetica Ultra Light....
But Obi-wan Kenobi, I really like the font example you used. What font/font character (square bracket) did you use?
Obi-wan Kenobi wrote:
So, define the size you want, select the glyph, make: Cmd-Alt-Shift-O (make iras outline) and apply a white stroke (here: 1 pt):
Thanks for this suggestion.
9. Re: Changing stroke [reduction] thickness of a font (Glyph)?
SRiegel Sep 10, 2014 1:58 PM (in response to shawninvancouver)Here are some thin fonts that are free
http://www.design-by-izo.com/2011/01/07/10-free-classy-thin-fonts/
maybe one of these will work for you.
11. Re: Changing stroke [reduction] thickness of a font (Glyph)?
Peter Spier Sep 10, 2014 3:55 PM (in response to shawninvancouver)Would just using vertical scale on the glyph distort it too much?
12. Re: Changing stroke [reduction] thickness of a font (Glyph)?
Obi-wan Kenobi Sep 10, 2014 4:01 PM (in response to Peter Spier)Reading Peter's answer makes me think to this solution: using a maths equation editor as MathType or MathMagic does it!
13. Re: Changing stroke [reduction] thickness of a font (Glyph)?
shawninvancouver Sep 11, 2014 2:50 PM (in response to shawninvancouver)Thanks again everyone. You folks were awesome, yet again!
Too bad I can only select one answer as correct. I ended up drawing my own bracket b/c I didn't have any of the fonts you folks demonstrated with.
14. Re: Changing stroke [reduction] thickness of a font (Glyph)?
shawninvancouver Sep 11, 2014 2:51 PM (in response to Peter Spier)Peter Spier wrote:
The action flattens the font but not the thickness. I wish it were that easy.
15. Re: Changing stroke [reduction] thickness of a font (Glyph)?
Cool. Thank you! Too bad I didn't see this msg until now.
16. Re: Changing stroke [reduction] thickness of a font (Glyph)?
Peter Spier Sep 11, 2014 2:55 PM (in response to shawninvancouver)shawninvancouver wrote:
The point is to start with a SMALL size glyph, then make it taller.
