1 Reply Latest reply on Apr 10, 2007 4:02 PM by Newsgroup_User
    Variable comparison problem
    symmetricalMan Level 1
      Actionscript newbie.
      I have three variables that I call as follows:
      _global johnAlt = false;
      _global garyAlt = false;
      _global tonyAlt = false;
      I also have three buttons, each of which changes the value of each variable, like:
      on (release) {tonyAlt = true;}
      Later, I need to compare the three values, so I've written code like this:
      if ((johnAlt = true) && (garyAlt = true) && (tonyAlt = true))
      {gotoAndPlay(3);}
      else {stop();}
      It doesn't work.
      I've tried using all sorts of combinations of code, including using double ==.
      The only way I got it to work was this way:
      if ((johnAlt = garyAlt) && (garyAlt = tonyAlt) && (tonyAlt = johnAlt))
      ...which essentially is what I'm asking all along, because I'm testing to see when they're all 'true'. But, what if I was trying to compare specific values, like
      if ((car=red) && (gofaster=stripes) && (bigbutton=off))?
      I've checked the Flash help, and various forums, and from what I can see, my code is suppsoed to work.
      Any ideas?
        • 1. Re: Variable comparison problem
          Level 7
          Have a look at this http://www.smithmediafusion.com/blog/?p=235
          It has some logic that might help.
          Dan Mode
          --> Adobe Community Expert
          *Flash Helps* http://www.smithmediafusion.com/blog/?cat=11
          *THE online Radio* http://www.tornadostream.com <--check this
          *Must Read* http://www.smithmediafusion.com/blog
          "symmetricalMan" <webforumsuser@macromedia.com> wrote in message
          news:evh4j4$ksi$1@forums.macromedia.com...
          > variable,
          > like:
          > {gotoAndPlay(3);}
          > else {stop();}
          > It doesn't work.
          > see
          > values,
          > like
          > my
          > Any ideas?
