1 Reply Latest reply on Sep 10, 2014 9:24 PM by JJMack
    return the height of a selection using photoshop javascript??
    filterFactor Level 1
      So i am working on a script.
      I need to know the height of a selection I create using the magicWand via scriptlistener code
      The closest I can get is using the "doc.recordMeasurements( MeasurementSource.MEASURESELECTION, undefined);"
      that calls up the measurement analysis which will list the height of the selection. but i cant seem to pull the data out
      do i need to create a list and array to get that data into a variable?
        • 1. Re: return the height of a selection using photoshop javascript??
          There is a scripting forum Photoshop Scripting
          // enable double-clicking from Mac Finder or Windows Explorer
          #target photoshop // this command only works in Photoshop CS2 and higher
          // bring application forward for double-click events
          app.bringToFront();
          // Save the current preferences
          var startRulerUnits = app.preferences.rulerUnits;
          // Set Photoshop to use pixels
          app.preferences.rulerUnits = Units.PIXELS;
          if (hasSelection()) {
            makeLayer(); // Make Temp Work Layer
            app.activeDocument.selection.fill(app.foregroundColor);
            var LB = activeDocument.activeLayer.bounds;
            var LWidth = (LB[2].value) - (LB[0].value);
            var LHeight = (LB[3].value) - (LB[1].value);
            activeDocument.activeLayer.remove();
            alert("Width = " +  LWidth + "px     Height = " + LHeight +"px" + "\nTop Left " +  LB[0].value + "," +  LB[1].value + "  Bottom Right "  +  LB[2].value + "," +  LB[3].value  );
          else alert("There is no Active Selection");
          // Return the app preferences
          app.preferences.rulerUnits = startRulerUnits;
          ////// check for seelction //////
          function hasSelection(){
          var ref = new ActionReference();
          ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
          var docDesc = executeActionGet(ref);
          var hasSelection = docDesc.hasKey(stringIDToTypeID("selection"));
          return hasSelection;
          function makeLayer(){
            var idMk = charIDToTypeID( "Mk  " );
               var desc4 = new ActionDescriptor();
               var idnull = charIDToTypeID( "null" );
                   var ref3 = new ActionReference();
                   var idLyr = charIDToTypeID( "Lyr " );
                   ref3.putClass( idLyr );
               desc4.putReference( idnull, ref3 );
            executeAction( idMk, desc4, DialogModes.NO );
