2 Replies Latest reply on Sep 11, 2014 2:42 PM by try67
    Tabbing and extra clicks
    --csullivan
      I am not sure if this is related, but I have two issues with field focus.
      I have all fields hidden until the previous field is validated:
      On Field A, I have a validation script-
      if(event.value=="")
      this.getField("fieldB")=display.hidden
      else
      this.getField("fieldB")=display.visible
      When I attempt to tab to the next field (Field B) it is highlighted, but the cursor will not enter the field - I have to manually click. in those field that are already visible, I have no problem tabbing.
      I have the same validation script in a dropdown list (along with a calculation that is performed based on the value and the result is entered into a mother field, which is hidden using the above script). However, the calculation does not appear when I first select the item in the drop down. I then have to click in the drop down list field again to have it calculate.
      Are these related or two different issues
      csullivan
