2 Replies Latest reply: Sep 21, 2014 8:39 PM by I Need U RSS
    Bound drop-down list export results as text from list rather than item value
    I Need U Community Member
      LiveCycle Designer: I have a table with 4 drop-down lists which are bound (I've manually added the drop down text in the list items box & selected the specific items values in Binding). The first drop-down list choice is a code that on selection populates the other three drop boxes with related information. I have an add row button under this. When the data is submitted the results for these lists are the list item values, but I need the list item text in the exported data. So, what I'd like is to know is this:
      How do I write the script I need to change the bound item value in the result to text and where should put it on a change or exit event?
      I've been searching for a day to find the answer with no luck. Thanks in advance.
