2 Replies Latest reply on Sep 15, 2014 12:40 AM by Laubender
    Ink Areas
    SBlack
      Does anybody have a script for calculating the area of a spot or seperation in in indesign, for litho ink consumption?
      I am not after ink saturation percentages, I need total area within the printable confines.
        • 1. Re: Ink Areas
          Trevorׅ Adobe Community Professional
          Is this something you could do manually and if so how?
          • 2. Re: Ink Areas
            @Trevor – if you want it accurate this can only be calculated by counting pixels in the rendered highres 1-bit image that is used for platesetting when all transparency is flattened, all color management, all the screening is done and the colors are separated.
            If you want a well-informed guess, I would recommend the following steps:
            1. Output to PDF with simulate overprinting
            2. Render the PDF in PhotoShop to pixels
            3. Evaluate the pixels with the statistic tools there*
            * Don't ask me if this can be done by ExtendScript (but you could ask the folks in the PhotoShop Scripting Forum)
            Uwe
