• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
alpha lists
New Here ,
Apr 06, 2007 Apr 06, 2007
RoboHelp 5x --- In css, created an alpha list, which, when applied looks like an alpha list in WYSIWYG, but when viewing it, it is a numbered list, even after saving the project. Checked the css in Notepad and list-style: lower-alpha; is in there. ????
Views
652
Translate
Translate
Report
Report
Community guidelines
community guidelines
Contributor ,
Torpike -
Hello, and welcome to the forum.
Most likely, your list has a class or id assigned to it, and that class has some overriding styles attached. Look at your list itself for any 'class =' or 'id =' statements. Look topside, or in your style sheet for the css statements that might apply. We'd need to look at the actual markup to provide anything more specific.
Votes
Translate
Translate
Report
Report
New Here ,
Hi Roger,
Thanks, I think you are right. I found id= at the begining of each list item, but short of deleting each one manually, I don't know how to get rid of it. I did delete them in one topic and it worked, but I have a huge project, over 1200 topics, so I would need a more automated method. Have any ideas? I don't know how it got into this css. Even when I copy another css this "id=" shows up.
Thanks, Torpike
Votes
Translate
Translate
Report
Report
Contributor ,
Torpike -
I like ReplaceEm, a nifty app that will search across multiple lines, and multiple documents, and has some very flexible wildcard features. Best of all, you can save your searches to repeat again later, with just three clicks; it's painless, and free. If you have FAR, that will work too, plus it has mucho mondo other features. It won't save your search, though, and it's not free.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 09, 2007 Apr 09, 2007
Hi Roger,
I downloaded ReplaceEM and it looks like a great little utility. However, I can't figure out how to make it look at the source code and not the RoboHelp html words that I wrote. I've been playing with it now for about 3 hours.
Torpike
Votes
Translate
Translate
Report
Report
Advisor ,
Roger:
You state that FAR "won't save your search." I meant to say something the last time this was claimed (don't remember if it was you or not), but that isn't quite right.
Saving searches in FAR entails a two-prong approach:
* Filter files and folders, retrieve results, and save them as a "List" for future use.
* Create "Search Definitions," which can then be used to Find & Replace against any folders, whether saved lists or not.
Leon
Votes
Translate
Translate
Report
Report
Contributor ,
Apr 12, 2007 Apr 12, 2007
So, you 1) define the family of files, and 2) define the search and replace items. That works for me.
thanks for the clarification!
Votes
Translate
Translate
Report
Report
Advisor ,
Apr 13, 2007 Apr 13, 2007
LATEST
Yes, Roger. It depends on whether your specific changes will be repetitive over time, or simply a "one-off" instance.
For example, I'm ni the process of adding content to 2.5K topics in 42 projects, but the logistics of hijacking the projects from 7 writers for an unlimited period of time was unlikely. I created all the Search Definitions I needed, but no file Lists because I'm not likely to access them again soon. I simply Add Files from each project as I go along.
Leon
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
