2 Replies Latest reply on Sep 11, 2014 11:59 AM by pixxxel schubser
    Get dimensions of a transformed shape/object
    poortip87 Level 1
      Hi All,
      I am implementing an extension for InDesign CS6 using Ext Builder 2.1. The extension requires to get some page-item properties in active document and write to a file. I have been able to do most of it.
      This issue is in getting bounds and coordinates of transformed page-items. I am able to get the correct bounds for simple page-items. For eg a simple page-item is,
      Here is the transformed page-item,
      Below is the code I am using to calculate the left, top, width and height.
      var bounds:Array = pgItem.geometricBounds as Array;
        if(bounds)
             if(pgItem.strokeWeight)
                  var stroke:Number = pgItem.strokeWeight.valueOf();
                  if(pgItem.strokeAlignment == StrokeAlignment.CENTER_ALIGNMENT)
                       // top
                       if(bounds[0])
                            bounds[0] -= stroke/2;
                       else
                            bounds[0] += stroke/2;
                       // left
                       if(bounds[1])
                            bounds[1] -= stroke/2;
                       else
                            bounds[1] += stroke/2;
                       bounds[2] += stroke/2;
                       bounds[3] += stroke/2;
                  else if(pgItem.strokeAlignment == StrokeAlignment.OUTSIDE_ALIGNMENT)
                       if(bounds[0])
                            bounds[0] -= stroke;
                       else
                            bounds[0] += stroke;
                       if(bounds[1])
                            bounds[1] -= stroke;
                       else
                            bounds[1] += stroke;
                       bounds[2] += stroke;
                       bounds[3] += stroke;
             var left:Number = bounds[1];
             var top:Number = bounds[0];
             var width:Number = bounds[3] - bounds[1];
             var height:Number = bounds[2] - bounds[0];
      Can anyone tell what I am missing? I am sure I need to handle something for the transformed items.
      Please guide.
      Thanks!
