3 Replies Latest reply on Sep 16, 2014 1:24 PM by Michael Thornburgh
    NetGroup problems connecting devices with different internet connection
    AndreyE Level 1
      Create a chat using technology Cirrus (p2p) and class NetGroup.
      If the device is a mobile phone, and has network via 3G or 4G, then connect to the same group with other devices is not happening.
      For example, there are a PC and the mobile device:
      1 If both are connected to one Wi-Fi:
      onNetConnectionNetStatus: NetConnection.Connect.Success
      onNetConnectionNetStatus: NetGroup.Connect.Success
      onNetGroupNetStatus: NetGroup.Neighbor.Connect
      A connection is made.
      2 If both are connected to different Wi-Fi:
      3.If one device is connected to Wi-Fi, and the other to a 3G or G4
      No connection.
      Sample code that was tested:
      package {
      import flash.display.Sprite;
      import flash.events.NetStatusEvent;
      import flash.net.GroupSpecifier;
      import flash.net.NetConnection;
      import flash.net.NetGroup;
      import flash.text.TextField;
      public class NetGroupSample extends Sprite {
         private static const CIRRUS_URL:String = "rtmfp://p2p.rtmfp.net";
         private static const CIRRUS_DEVELOPER_KEY:String = "************************";
         private var _netConnection:NetConnection;
         private var _netGroup:NetGroup;
         private var _outputTextField:TextField;
         public function NetGroupSample() {
        _outputTextField = new TextField();
        _outputTextField.width = this.stage.stageWidth;
        _outputTextField.height = this.stage.stageHeight;
         this.addChild(_outputTextField);
        _netConnection = new NetConnection();
        _netConnection.addEventListener(NetStatusEvent.NET_STATUS, this.onNetConnectionNetStatus);
        _netConnection.connect(CIRRUS_URL, CIRRUS_DEVELOPER_KEY);
         private function onNetConnectionNetStatus(event:NetStatusEvent):void {
         this.traceToOutput("onNetConnectionNetStatus:", event.info.code);
         switch (event.info.code) {
         case "NetConnection.Connect.Success":
         var gspec:GroupSpecifier = new GroupSpecifier("Group1");
        gspec.multicastEnabled = true;
        gspec.postingEnabled = true;
        gspec.serverChannelEnabled = true;
        gspec.objectReplicationEnabled = true;
        gspec.routingEnabled = true;
        _netGroup = new NetGroup(_netConnection, gspec.groupspecWithAuthorizations());
        _netGroup.addEventListener(NetStatusEvent.NET_STATUS, this.onNetGroupNetStatus);
        break;
         private function onNetGroupNetStatus(event:NetStatusEvent):void {
         this.traceToOutput("onNetGroupNetStatus:", event.info.code);
         private function traceToOutput(...strings):void {
        _outputTextField.appendText(strings.join(" ") + "\n");
      Tested on Adobe AIR SDK 3.2, 3.4, 13.0.0.111
