2 Replies Latest reply on Sep 11, 2014 2:30 PM by areohbee
    Can I move collections to a new catalog?
    AP Photo
      I I needed to start a new catalog with over 100,000 images.  Is there anyway I can move the old collections from an old catalog to the new catalog?  Thanks for your reply.
      Alan
        • 1. Re: Can I move collections to a new catalog?
          john beardsworth Adobe Community Professional & MVP
          You can use File > Export as Catalog and the corresponding File > Import from Another Catalog.
          However, 100k should not force you to fragment control of your workflow into separate catalogues. I routinely work on one that is over 5 times that size, and the only thing that's slower is backing up, which is done in non-working time. See http://kb2.adobe.com/cps/400/kb400808.html and above all, optimise your catalogue every so often.
          • 2. Re: Can I move collections to a new catalog?
            areohbee Level 6
            Hi Alan,
            Yes - here is one easy way:
            1. Download and install MiscLrScripts (they're free, and I wrote them).
            2. In source catalog, invoke 'Export Collections and Sets' script.
            3. In target catalog, invoke 'Import Collections and Sets' script.
            Note: you can do publish collections too using this method (such is not the case via 'Import from Another Catalog').
            PS - I recommend reading the documentation before embarking.
            Rob
