0 Replies Latest reply on Sep 11, 2014 9:27 AM by RichardMcKenna
    Can't make HTTPS call to sub domain on ColdFusion 10 Standard
    RichardMcKenna Level 1
      I'd like to start by saying I didn't have this issue on CF9 Standard but recently updated to CF10 and now have the issue.
      I have a site and several sub domains running on IIS and CF10. They are all set up as separate sites but share a wildcard SSL certificate for *.domain.com
      I'm doing cfhttp calls between the sites. They work fine over http but over https, I get the all too common 'I/O Exception: peer not authenticated' error.
      Charset [empty string]
      ErrorDetail I/O Exception: peer not authenticated
      Filecontent Connection Failure
      Header  [empty string]
      Mimetype    Unable to determine MIME type of file.
      Responseheader    struct [empty]
      Statuscode  Connection Failure. Status code unavailable.
      Text    YES
      So I figured I needed to install the SSL certificate. I've installed the certificate in the correct key store and verified it's there using keytool -list and restarted. I even tried uninstalling and reinstalling it using the CertMan admin plugin but still get the error.
      I know there are other work arounds for this problem with Enterprise but as I'm running standard I can't use them.
      Does anyone have any suggestions? I'm pretty much stumped without https.
