4 Replies Latest reply on Mar 26, 2007 4:05 AM by Newsgroup_User
    A fileio problem
    wgb14 Level 1
      Hi all,
      I have the following code:
      global customscript,whichAIML
      -- write the aiml file
      on saveAnINI2
      -- set Question = the text of member "greeklish"
      set Question = the text of member "Q"
      gFileIO =new (xtra "FileIO")
      gFileIO.createFile("aiml\"&whichAIML&"" & ".aiml")
      gFileIO.openFile ("aiml\"&whichAIML&"" & ".aiml",0)
      gFileIO.writeString ("<aiml>" & RETURN)
      setPosition(gFileIO,getLength(gFileIO))
      gFileIO.writeString("<category>" & RETURN & "<pattern>"&Question&"</pattern>" &RETURN & "<template>" & customscript &".hap" & "</template>" & RETURN & "</category>" & RETURN)
      gfileIO = VOID
      end
      Although its working, somehow it writes the same text lines twice. Any ideas what is wrong with it? I want the string to be wrirtten once and not twice. What am i doing wrong?
        • 1. Re: A fileio problem
          johnAq
          What you might be seeing is a quirk of fileio whereby if you write over an existing file, and the old length is longer than the new length, the extra data from the original is kept at the end of the file.
          To work around this, first delete the old file and create a new empty file in its place and write to that
          hth
          johnAq
          • 2. Re: A fileio problem
            wgb14 Level 1
            Thanks for the reply, the problem is that i want to write the data in the same file. Is there any other solution?
            • 3. Re: A fileio problem
              Level 7
              Perhaps you could try opening the file before creating it (in case it
              already exists and you want to append to it).
              Or use FileXtra4 or Buddy API to check for its existence before creating it.
              • 4. Re: A fileio problem
                Level 7
                1) Read all data in from file.
                2) Modify data in memory.
                3) Save data to a different file.
                4) Delete original file.
                5) Rename saved file to original file.
                Andrew
