6 Replies Latest reply on Sep 11, 2014 6:45 PM by A.T. Romano
    Old Video Camera
    OldCamera
      I have an older video camera - DV Sony DCR-PC9 NTSC which I have used with Premier Elements 8.  I am thinking of purchasing Premier Elements 12.  Would this software work with this camera?  I upload the video through a fire wire IEEE 1394-4.
        • 1. Re: Old Video Camera
          Video from a tape camera is either DV AVI (Standard Definition) or MPG if it is an HDV camera... both of which work with the current Premiere Elements
          The Elements Tutorial Links Page http://forums.adobe.com/thread/1275830 has links to the user guides... and you may also download the 30 day trial version to find out how it works on your computer
          • 2. Re: Old Video Camera
            A.T. Romano Level 7
            oldcamera
            This is the Adobe document on DV and HDV capture firewire into Premiere Elements Capture Window (applicable to versions 11 and 12)
            Adobe Premiere Elements 11 * Capture video
            I would strongly recommend that you download and install the free 30 day tryout of Premiere Elements 12 from Adobe now if your interest is specific to
            Premiere Elements 12. Adobe is expected to release a new version of Premiere Elements sometime this month. When it does, the Premiere Elements 12 tryout will be replaced with the newly released version's tryout.
            What is your computer operating system?
            ATR
            • 3. Re: Old Video Camera
              OldCamera Level 1
              It uses Mini DV tapes if that helps.
              • 4. Re: Old Video Camera
                OldCamera Level 1
                Windows 7
                • 5. Re: Old Video Camera
                  Paul787 Level 3
                  Your camera should work fine with PRE12 for importing. I import my MiniDV files from an older Panasonic camera over Firewire and PRE works great.
                  • 6. Re: Old Video Camera
                    A.T. Romano Level 7
                    oldcamera
                    Thanks for the information that you are using Windows 7 assumed 64 bit computer.
                    Paul787's post is encouraging but his old Panasonic camera over firewire is not your old Sony camera over firewire. So, please consider your DV data capture firewire into the tryout Premiere Elements 12 or later Capture Window before purchase to avoid surprises.
                    Case in point, I started doing some homework on Premiere Elements 12 Project Archiver/Archive Project option whose description has been perpetuated in each version's help files (at least 4 through 12). Come to find out, that feature has not worked as advertised since Premiere Elements 8.
                    So best not to take anything for granted, and determine first hand what works for you, especially if you can do that without additional cost.
                    Please update us on your progress when you get a chance.
                    Thanks.
                    ATR
