1 Reply Latest reply on Apr 7, 2007 4:55 PM by MotionMaker
    CheckBox within MovieClip will not select
    masterkrang Level 1
      I have a CheckBox within a MovieClip, and I'm simply trying to set the selected property to true.
      my movie clip's instance name is "data" and my CheckBox component's instance name is "opt1".
      My code is:
      data.opt1.selected = true;
      Anybody know why this code doesn't work???
      I only have trouble with the CheckBoxes within the movie clips, all other checkbox.select properties work fine.
      //thanks :) !!!
        • 1. Re: CheckBox within MovieClip will not select
          MotionMaker Level 1
          This works fine.
          Test example was a movieclip with instance name data on frame 1. It contains a checkbox named opt1. The code you posted in the frame.
          Perhaps where you have the code the reference is inappropriate. You have the code inside a child or the data clip or a sibling of the data or somewhere other than the timeline to which data is attached.
