1 Reply Latest reply on Sep 13, 2014 2:22 PM by snowhiterw1
    Need to save .SVG text as draw with vector graphic tools like line, circle, rect and then save to local file.
    snowhiterw1
      I have written an image generator that draws using flash.display.Graphics like circle, rect and line.  I need to save the .svg text for each command and write the result to a vector. svg file so the resulting drawing can be subsequently resized without loss of detail.
        • 1. Re: Need to save .SVG text as draw with vector graphic tools like line, circle, rect and then save to local file.
          snowhiterw1 Level 1
               figured it out myself.  This is the class I created - it's all I need:
          package classes
            import flash.geom.Point;
            public class drawSVG
             public var svgData:String = "";
             private var svgID:Number = 1;
             public function drawSVG()
             public function start(svgTitle:String,inw:Number,inh:Number,inAngle:Number) : void
             svgData = '<svg width="' + inw.toString() + '"' + ' height="' + inh.toString() + '"' +
                               ' x="' + -inw/2 + '" y="' + -inh/2 + '" xmlns="http://www.w3.org/2000/svg">\r\n';
             svgData += '<g transform="rotate(' + inAngle + ' ' + '0' + ' ' + '0' + ')">\r\n';
             svgData += '<title>' + svgTitle + '</title>\r\n';
            public function drawLine(inStrokeClr:String,inStrokeW:uint,
                      inAngle:Number=0) : void  // angle in degrees
             if (inStrokeW != 0)
               var x1:Number = inx + inw/2;
               var y1:Number = iny - inh/2;
               var x2:Number = inx + inw/2;
               var y2:Number = iny + inh/2;
               var svgStrokeClr:String = inStrokeClr.split("0x").join("#");
              svgData += '<line x1="' + x1 + '" y1="' + y1 + '" x2="' + x2 + '" y2="' + y2 + '"';
              svgData += ' style="';
              svgData += ' stroke:' + svgStrokeClr + ';stroke-width:' + inStrokeW;
              svgData += '"';
              svgData += ' id="line_' + svgID.toString() + '"';
              svgData += '/>\r\n';
          public function drawEllipse(inStrokeClr:String,inStrokeW:uint,
             if (isFill || inStrokeW!= 0)
               var svgFillClr:String = infillClr.split("0x").join("#");
               svgData += '<ellipse rx="' + inw/2 + '"'' ry="' + inh/2 + '"' +
                                  ' cx="' + inCenterX +'"' + ' cy="' + inCenterY + '"';
               if (isFill)
                  svgData += ' fill:' + svgFillClr;
               if (inStrokeW!= 0)
                  svgData += ' stroke:' + svgStrokeClr + ' stroke-width:' + inStrokeW;
               svgData += '"';
               svgData += ' id="ellipse_' + svgID.toString() + '"';
          public function drawRectangle(inStrokeClr:String,inStrokeW:uint,
                                     isCenter:Boolean,inAngle:Number=0) : void  // angle in degrees
               var x:Number = (isCenter ? inx-(inw/2) : inx);
               var y:Number = (isCenter ? iny-(inh/2) : iny);
               svgData += '<rect x="' + x + '" y="' + y + '"' +
                    ' width="' + inw + '" height="' + inh + '"';
               if (isFill)
               if (inStrokeW!= 0)
                   svgData += ' stroke:' + svgFillClr + ' stroke-width:' + inStrokeW;
               svgData += '"';
               svgData += ' id="rect_' + svgID.toString() + '"';
          public function terminate() : void
             svgData += "</g>\r\n";
             svgData += "</svg>";
