6 Replies Latest reply on Apr 8, 2007 10:42 PM by kglad
    How I do?
    slomziin
      In advertisement on category -קטלוג- look move images and If you press on image
      you look big image, How I do?
      thank you .
        • 1. Re: How I do?
          Dewdan
          My friend,
          First, your addres link is wrong, the right one is http://tntrealife.com/summer2007/
          Second, Since i can't read Hebrew i had really dificult to find -קטלוג
          Third, your question is so unclear. It sound like look at HOW I DO THAT! http://2adanced.com
          So please be more specific.!!!
          • 2. Re: How I do?
            slomziin Level 1
            Hello Txarán!
            In advertisement on category -SEE IT-you press on second word
            look move images and If you press on image you look big image
            HOW I DO THAT?
            I hope my question is clear.
            thank you .
            • 3. Re: How I do?
              that's a scrolling movieclip below a mask that scrolls in response to the mouse position. you can check scrolling movieclip on this forum or elsewhere.
              below is code for a class extension of the movieclip class that i wrote. it allows horizontal, vertical or both scrolling. the example you cited uses vertical scrolling:
              • 4. Re: How I do?
                slomziin Level 1
                Im not master...if I receiver .fla source, I use it for my images.
                thank you .
                • 5. Re: How I do?
                  Sketchsta Level 1
                  The code kglad posted abov IS NOT a .FLA, its a .AS file for you to call from inside your movie.
                  all the functions are already made, all you have to do is call to the specific function you want.
                  Have a read through the code kglad gave you, and see which function you need.
                  • 6. Re: How I do?
                    save that code in a file named scrollingMC.as and put that file in the following sub directories of your fla:
                    com.gladstien.extensions.
                    then in your fla create an empty movieclip and give it a linkage id (if needed) and class:
                    com.gladstien.extensions.scrollingMC
                    then add your thumbnails to this movieclip. add your mask movieclip (say with instance name maskingMC) to the stage. finally, execute:
                    initializeScrollF (false, true, 3, maskingMC); // <- for a vertical scroller. adjust the 3 for speed control.
