1 Reply Latest reply on Apr 9, 2007 7:10 AM by peterent
    FLEX 2 Bug ??
    ::_ASTOR_DESIGN_::
      Hello,
      Check this simple example :
      http://astronaute.net/_temp/flex/flexTest3/flexTest3.html
      source : http://paste.sharewonders.com/Default.aspx?fv=9aae6eca-becf-4c44-8797-0974e44c2852
      if you first click on CHANGE LABELS, only the label in first view is changed !
      BUT, if you first change views and then click on CHANGE LABELS, both are changed !
      Whats up, another bug ??
      Thank you for helping, i need to be able to change labels in different views, language implementation...
        • 1. Re: FLEX 2 Bug ??
          peterent Level 2
          Your event handlers should not be in { } - that's causing them to be evaluated and the result of the evaluation being assigned as the event handler. You want an expression assigned as the event handler, not the result of evaluating the expression.
