1 Reply Latest reply on Sep 14, 2014 3:59 AM by BKBK
    set variables from recordset
    ghanna1 Level 1
      I have an SQL table that I store OrderID, ItemID, Qty.  There are 15 possible ItemID's (will never be more).  I need to output the order into a single table row that shows the orderID and the qty for each item.
      For example:
      <cfquery name="orders" datasource="xyz"
      Select *
      From solditems
      Where orderid = 'Order1"
      </query>
      Would return something like:
      Order1, Item3, 6
      Order1, Item4, 7
      Order1, Item18, 10
      The table needs to look like:
      <tr>
      <td>#orderID#</td>
      <td>#item1qty#</td>
      <td>#item2qty#</td>
      <td>#item3qty#</td>
      <td>#item4qty#</td>
      <td>#item5qty#</td>
      <td>#item6qty#</td>
      <td>#item7qty#</td>
      <td>#item8qty#</td>
      <td>#item9qty#</td>
      <td>#item10qty#</td>
      <td>#item11qty#</td>
      <td>#item12qty#</td>
      <td>#item13qty#</td>
      <td>#item14qty#</td>
      <td>#item15qty#</td>
      </tr>
      I'm at a loss trying to figure out how to match the row from the results of the record set into the right #itemXqty#.
      Hope I explained this well and thanks in advance for pointers in the right direction!
      Gary
        • 1. Re: set variables from recordset
          BKBK Adobe Community Professional & MVP
          You could do something like
          <cfoutput><table border="1"><tr><th>#orders.orderID#</th></cfoutput>
          <cfoutput query="orders">
              <td>#itemID##qty#</td>
          </cfoutput>
          </tr></table>
          For a start, your query would be more efficient using "select orderID, itemID, qty" instead of "select *" (assuming, of course, that the table has more than the 3 columns).
