7 Replies Latest reply on Sep 15, 2014 6:41 PM by A.T. Romano
    Error 1317
    DoneBySight
      My Adode Premiere Elements 11 just stop working one day when I was trying to edit videos. I have tired to uninstall it and when I try to re install it I am getting an error message.
      Adobe Premiere Elements 11 - set up
      Error 1317. An error occurred while attempting to create the directory C:\Program Files\Adobe\Adobe Premiere Elements 11
      I need help with getting this part of my program to start working again.
      Donebysight@gmail.com
        • 1. Re: Error 1317
          A.T. Romano Level 7
          Done
          What computer operating system is your Premiere Elements 11 running on? For now I will assume Windows 7, 8, or 8.1 64 bit.
          1. Go to Control Panel/Programs and assure that Premiere Elements 11 is not somehow listed as an installed program. If it is, uninstall it.
          2. Do a free ccleaner run through (regular cleaner and registry cleaner parts) to get rid of leftovers from incomplete uninstall and reinstalls.
          CCleaner - Download
          3. Then reinstall Premiere Elements 11 with the antivirus and firewall(s) disabled.
          The key to this will be the ccleaner clean up. We will consider what next based on your results from the above.
          Thanks.
          ATR
          Add On...It is not clear if you created this reinstall issue with the uninstall/reinstall or whether it was part of the original problem that caused you to
          uninstall the program. For that we need to look deeper into "My Adode Premiere Elements 11 just stop working one day". But, for now let us focus
          on the above.
          • 2. Re: Error 1317
            DoneBySight Level 1
            How do disable my firewall? still getting the same error message
            On Fri, Sep 12, 2014 at 8:31 PM, A.T. Romano <forums_noreply@adobe.com>
            • 3. Re: Error 1317
              DoneBySight Level 1
              I am running Windows 8
              On Mon, Sep 15, 2014 at 4:05 PM, Travell Williams <donebysight@gmail.com>
              • 4. Re: Error 1317
                DoneBySight Level 1
                The issue occurred after I unistalled the software and then tried to
                reinstall it to my computer.
                I still have access to Adobe Photoshop Elements 11 installed and it is
                working. I am still getting the same error message when I try and reinstall
                Adobe Premiere Elements 11 after I have done the ccleaner.
                • 5. Re: Error 1317
                  A.T. Romano Level 7
                  Done
                  Thanks for the replies
                  What antivirus program do you have? Disabling the firewall(s) may get more complicated if you have McAfee which might take control of firewall as well as antivirus.
                  But, here is an article which applies to working with the Windows 8.1 firewall. It should apply to Windows 8 also.
                  Windows Firewall from start to finish - Windows Help
                  Please let us know if that works for you.
                  Thank you.
                  ATR
                  • 6. Re: Error 1317
                    DoneBySight Level 1
                    This didn't work either....
                    I have turn the firewall off
                    I am still getting the Error message.....
                    What's next?
                    Is their somewhere local in Atlanta that I can take the product into and my
                    laptop to have them look at what is causing the error?
                    On Mon, Sep 15, 2014 at 4:53 PM, A.T. Romano <forums_noreply@adobe.com>
                    • 7. Re: Error 1317
                      A.T. Romano Level 7
                      Done
                      Typically Adobe offers help for the current version via its online Adobe Chat. No walk-in type Adobe centers for Premiere Elements troubleshooting.
                      Even Adobe Chat processes troubleshooting for purchased/registered/current version with an emphasis on current version. And, you have 11. The current version 12 will soon no longer be the current version. But, you can try to contact Adobe Chat anyway to determine if the current version requirement for troubleshooting might be extended to version 11.
                      Contact Customer Care
                      Premiere Elements
                      Adobe ID, Signing In
                      Adobe ID, signing in, account help
                      Chat Panel
                      As of a few moments ago the Chat Panel was available and active. Ignore the titles, they are given to get to an available and active Chat Panel line for immediate help or direction to an Adobe Tech department for help.
                      Before you try for the Chat Panel contact, try deleting the Adobe Premiere Elements Prefs file or the whole 11.0 Folder in which it exists.
                      Local Disk C
                      Users
                      Owner
                      AppData
                      Roaming
                      Adobe
                      Premiere Elements
                      11.0
                      and in the 11.0 Folder is the Adobe Premiere Elements Prefs file that you delete. If that does not work, then delete the whole 11.0 Folder in which the Adobe Premiere Elements Prefs exists. Be sure to be working with Folder Options Show Hidden Files, Folders, and Drives active so that you can see the complete
                      path cited.
                      An almost last resort might be to create a new User Account with Administrative Privileges, install and try to run Premiere Elements from it.
                      Please review and consider and then we can determine what next is available.
                      Thanks.
                      ATR
