0 Replies Latest reply on Sep 17, 2014 7:30 AM by imfredde
    I can't get indesign server to listen on the admin port on osx.
    imfredde
      I've tried the example (with other ports) from the sdk with no success:
      "/Applications/Adobe InDesign CS6 Server/InDesignServer.app/Contents/MacOS/InDesignServer" -port 12345 -heartbeatupdateinterval 10 -adminport 18485
      The port isn't showing when I list the ports using lsof.
      When I use LBQ the same things occurs. We start the server with:
      /Applications/Adobe\ InDesign\ CS6\ Server/InDesignServer.command -configuration config_ior2 -pluginpath Server/Corba -iorfile ~/ServerTestFiles/LBQ/iors/ior2.txt -adminport 12342 -previews
      When sending a REST call with KillInstance pointing to the ior file the same error occur as when calling the port through curl:
      java.net.ConnectException: Connection refused
        at java.net.PlainSocketImpl.socketConnect(Native Method)
        at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:339)
        at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
        at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:18
      On windows it's working as expected.
      Is there something to take into account when starting on mac?
      System:
      Mac OSX (10.9.4)
      Indesign Server CS6 ver 8.0
