1 Reply Latest reply on Sep 15, 2014 9:53 AM by station_two
    Photoshop CS5 crashes when trying to edit from InDesign
    Eppie
      Photoshop CS5 crashes when I try to use the Edit With...command  Normally I click on the photo in the page in InDesign and use the command Edit With to alter the photo (resolution etc.)
      But lately I get the message that there is a problem and Photoshop cannot be opened. I had this problem a few times since installing Maverick but now it's all the time.
      I downloaded Java for OSX 2014-001 but nothing changed.
      Image not found says the report.
      Anyone?
      Here is what the report says...
      Process:         Adobe Photoshop CS5 [665]
      Path:            /Volumes/VOLUME/*/Adobe Photoshop CS5.app/Contents/MacOS/Adobe Photoshop CS5
      Identifier:      com.adobe.Photoshop
      Version:         ???
      Code Type:       X86-64 (Native)
      Parent Process:  launchd [171]
      Responsible:     Adobe Photoshop CS5 [665]
      User ID:         501
      Date/Time:       2014-09-15 14:11:53.892 +0200
      OS Version:      Mac OS X 10.9.4 (13E28)
      Report Version:  11
      Anonymous UUID:  44CCFA23-1321-C3D9-C956-9F68DA86356E
      Crashed Thread:  0
      Exception Type:  EXC_BREAKPOINT (SIGTRAP)
      Exception Codes: 0x0000000000000002, 0x0000000000000000
      Application Specific Information:
      dyld: launch, loading dependent libraries
      Dyld Error Message:
        Library not loaded: @executable_path/../Frameworks/adobe_caps.framework/Versions/A/adobe_caps
        Referenced from: /Volumes/VOLUME/*/Adobe Photoshop CS5.app/Contents/MacOS/Adobe Photoshop CS5
        Reason: image not found
      Binary Images:
          0x7fff67957000 -     0x7fff6798a817  dyld (239.4) <042C4CED-6FB2-3B1C-948B-CAF2EE3B9F7A> /usr/lib/dyld
      Model: iMac11,1, BootROM IM111.0034.B02, 4 processors, Intel Core i7, 2.8 GHz, 8 GB, SMC 1.54f36
      Graphics: ATI Radeon HD 4850, ATI Radeon HD 4850, PCIe, 512 MB
      Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353637334648302D4346382020
      Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353637334648302D4346382020
      Memory Module: BANK 0/DIMM1, 2 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353637334648302D4346382020
      Memory Module: BANK 1/DIMM1, 2 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353637334648302D4346382020
      AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 4.0.74.0-P2P
      Bluetooth: Version 4.2.6f1 14216, 3 services, 23 devices, 1 incoming serial ports
      Network Service: Ethernet, Ethernet, en0
      Network Service: AirPort, AirPort, en1
      Serial ATA Device: ST31000528ASQ, 1 TB
      Serial ATA Device: OPTIARC DVD RW AD-5680H
      USB Device: Hub
      USB Device: Photosmart 6510 series
      USB Device: Intuos5 touch L
      USB Device: BRCM2046 Hub
      USB Device: Bluetooth USB Host Controller
      USB Device: Internal Memory Card Reader
      USB Device: Hub
      USB Device: Keyboard Hub
      USB Device: Apple Keyboard
      USB Device: My Passport 0748
      USB Device: IR Receiver
      USB Device: Built-in iSight
      Thunderbolt Bus:
        • 1. Re: Photoshop CS5 crashes when trying to edit from InDesign
          Level 5
          Ik kan de nederlandse taal wel begrijpen.
          The Dutch text in your first screen shot is telling you that CS5 is not compatible with your operating system.
          I have no idea if CS5 is incompatible with Mavericks or not;  I stuck to Lion 10.7.5.  Hope a Mavericks user chimes in.
          Incidentally, if you're on Mavericks, how come you are getting the Lion logo?
          Re Java: I don't think Java has anything to do with Photoshop.
          Did you try re-booting your Mac?
          Wait a second!  Did you move the Photoshop application!    That path is not where it's supposed to be!
