5 Replies Latest reply: Sep 19, 2014 2:50 PM by rudytj RSS
    non-scripter attempting a metatagging script
    rudytj Community Member
      my script is doing everything i want except it is converting all spaces and periods to semicolons in the final metatag and i cannot figure out why.
      It will be VERY obvious that the attached script is nothing but a bunch of snippets clipped together to perform most of what i want...
      I want to run this script at the end as i am completing a project to insert the needed metatags.
      i want the project name
      i want the copyright info
      i want keywords to include all images used in the document
      i want to be able to add keywords.
      to run this script you will need a character style called    KeywordsCStyle
      //-----document title and copyright---------
      var myDocument = app.activeDocument;
      with (myDocument.metadataPreferences){
          //author = "Adobe";
          copyrightInfoURL = "UPMC.com"
          copyrightNotice = "© 2014 UPMC";
          copyrightStatus = CopyrightStatus.yes;
          //description = "Example of xmp metadata scripting in InDesign CS";
          documentTitle = myDocument.name.split(".indd")[0];
          //jobName = "XMP_Example_2003";
          //var myNewContainer = createContainerItem("http://ns.adobe.com/xap/1.0/", "email");
          //setProperty("http://ns.adobe.com/xap/1.0/", "email/*[1]", "someone@adobe.com");
              //author = "scott rudy";
      //var curDocTitle = app.activeDocument.metadataPreferences.documentTitle;
      //var curAuthor = app.activeDocument.metadataPreferences.author;
      var curKeywords = app.activeDocument.metadataPreferences.keywords;
      Array.prototype.unique = function (){
          var r = new Array();
          o:for(var i = 0, n = this.length; i < n; i++){
              for(var x = 0, y = r.length; x < y; x++){
                  if(r[x]==this[i]) continue o;}
              r[r.length] = this[i];}
          return r;
      function addXMP(/*find GREP*/findString, /*para style*/paraStyle, /*chr style*/chrStyle, /*insert to*/XMPdest){
        // reset search fields
        app.findGrepPreferences = NothingEnum.nothing;
        app.changeGrepPreferences = NothingEnum.nothing;
        // setting search parameters
        if(findString)app.findGrepPreferences.findWhat = findString;
        if(paraStyle)app.findGrepPreferences.appliedParagraphStyle = paraStyle;
        if(chrStyle)app.findGrepPreferences.appliedCharacterStyle = chrStyle;
        switch (XMPdest){
          // insert keywords
          case "Keywords":
            var myKeywords = app.activeDocument.findGrep();
            var myKeys = Array();
            // loop through keywords and get contents
            for(var i = 0; i < myKeywords.length; i++)
              myKeys.push(myKeywords[i].contents);
            //myKeys.sort();
            // delete duplicates
            //myKeys = myKeys.unique();
            // insert Keywords to document XMP
            app.activeDocument.metadataPreferences.keywords = myKeys;
            break;
          // Heading search/insert
          case "Heading":
            var myHeading = app.activeDocument.findGrep();
            app.activeDocument.metadataPreferences.documentTitle = myHeading[0].contents;
            break;
          // Author search/insert
         // case "Author":
          //  var myAuthor = app.activeDocument.findGrep();
          //  app.activeDocument.metadataPreferences.author = myAuthor[0].contents;
         //   break;
      // copy all image names //----------------------------------------------//
      f = app.activeDocument.textFrames.add({geometricBounds:[0,0,"20mm","20mm"]});
      f.contents = app.activeDocument.links.everyItem().name.join("\r");
      f.parentStory.texts[0].select();
      //-----------change character style-------------------//
      var cName = "KeywordsCStyle";
        var mCstyle = app.activeDocument.characterStyles.item(cName);
        if (mCstyle.isValid)
             app.selection[0].applyCharacterStyle(mCstyle);
      app.copy();
      // add Keywords
      addXMP("\\w{1,}","","KeywordsCStyle","Keywords");
      // add Heading
      //addXMP("","HeadingPStyle","","Heading");
      //add Author
      addXMP("","AuthorPStyle","","Author");
      //----delete image names textbox--------
      f.remove();
        • 1. Re: non-scripter attempting a metatagging script
          Jump_Over Community Member
          rudytj wrote:
          ...my script is doing everything i want except it is converting all spaces and periods to semicolons in the final metatag and i cannot figure out why...
          myKeys is an array of words.
          Each doc link is divided to words (even 1-letter long) since app.findGrepPreferences.findWhat property is set to "\\w{1,}"
               ==> means find Any Word Character (1+long)
          spaces and periods (and any "no-word" characters) are ommited.
          The question is how your keyword (created from a link name) supposes to look like?
          Jarek
          • 2. Re: non-scripter attempting a metatagging script
            i would like it to be the complete link name including the file extension and if i tag a phrase with the  character style "KeywordsCStyle"  i would like it to appear together as well. so i need the results to include the . before the file extension and any spaces between words.
            i will look into your lead and if you could continue to try to help me it would be most appreciated
            thank you in advance
            scott
            • 3. Re: Re: non-scripter attempting a metatagging script
              If your goal is to set an entire link name as a particular keyword ==> whole part with creating temporary textFrame, applying charStyle and findGrep() looks like unnecessary...
              the line:
              app.activeDocument.metadataPreferences.keywords = app.activeDocument.links.everyItem().name;
              should do a job
              Jarek
              • 4. Re: non-scripter attempting a metatagging script
                but that will eliminate my ability to tag words in the document with the character style "KeywordsCStyle" and have those words also appear in the metatag along with to the links.
                thank you for all your assistance in this task!!!
                scott
                • 5. Re: non-scripter attempting a metatagging script
                  I decided to give up on the character style to add keywords so i have to thank JUmp_over for all the help with my complete script...
                  here it is after i cleaned it up if anybody else has a need to add keywords to their indesign file (and ultimately to the resulting PDFs
                  //---------------------add document name-------------------------------
                  //-----------------------images to keywords--------------------------//
                  //-------------open file info dialog box---------------------
                  app.menuActions.itemByID(89092).invoke()
