1 Reply Latest reply: Sep 15, 2014 2:36 PM by Captiv8r RSS
    Captivate 8 - Mouse Click/Audio Narration Issue
    Elliott.Angie Community Member
      I receorded my software simulation, then added recorded narration to each slide afterward. When I go to preview my course, each time the mouse click happens, the audio narration volume is decreased slighly before, during, and slightly after the mouse click. I wish I could say it was by a neglible amount, but on certain slides it nearly "covers" my narration completely. I can't seem to find anything in the Adobe Captivate forums about this specifically, which is surprising! So that leads me to believe there is a setting somewhere. Has anyone else encountered this?
        • 1. Re: Captivate 8 - Mouse Click/Audio Narration Issue
          Captiv8r CommunityMVP
          Hi there
          The fact you don't see references to this in the forums is indicative of the fact that (at least for me) this is the first such report I've seen of this specific behavior. It could be that it's a bug. Following that, I'd strongly urge you to file a bug report on it using the link below:
          http://www.adobe.com/go/wish
          The behavior you are describing is consistent with what I might expect of the Background Audio and Slide narration.
          If you aren't using Background Audio, perhaps try clicking Audio > Import to > Background so you get the dialog. Then configure the dialog so you clear the option for reducing the volume.
          Once you have done this and clicked Save, click Audio > Remove > Background and see if that fixes anything. If not...
          Try clearing the preferences and publish again,
          My crystal ball is on the fritz and my psychic skills are nearly non-existent, so I can't tell whether you are using the Mac or the PC version. But if it's the PC version, here is how you clear the preferences.
          Close Captivate
          Right-click the Shortcut icon and choose Properties
          From the Shortcut tab, click the Open File Location button
          Windows Explorer should open - From there, locate the Utils folder
          Double-click the CleanPreferencesWin.bat file
          Restart Captivate and test
          Cheers... Rick
