3 Replies Latest reply on Apr 16, 2007 9:09 AM by dimival
    Java Collections and AS Objects
    bn_anand
      I tried the following for Remote Services:
      MXML File:
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml"
      layout="vertical" cornerRadius="2" backgroundGradientColors="[#b0bdf7, #b0bdf7]">
      <mx:RemoteObject id="c4cast" destination="c4cast"
      fault="handleError(event)">
      <mx:method name="getUser" result="handleUserLogin(event)" />
      </mx:RemoteObject>
      <mx:RemoteObject id="test" destination="test"
      <mx:method name="getUsers" result="handleUserLogin(event)" />
      </mx:RemoteObject>
      <mx:Script>
      <![CDATA[
      import mx.rpc.events.ResultEvent;
      import mx.events.ListEvent;
      import flash.events.MouseEvent;
      import mx.controls.Alert;
      import mx.rpc.events.FaultEvent;
      import mx.collections.ArrayCollection;
      //import com.cognizant.c4cast.*;
      import com.test.*;
      [Bindable]
      public var loggedInUser:TestUser = null;
      var userCollection:Array = null;
      public function handleError(event:FaultEvent):void{
      Alert.show("Error during Remote to C4CastService :"+event.toString());
      public function handleUserLogin(event:ResultEvent):void
      var res:ArrayCollection = event.result as ArrayCollection;
      Alert.show(""+res.length);
      if(res.length >= 1){
      loggedInUser = res[0];
      Alert.show(""+loggedInUser.applications[0]);
      //loginSuccess();
      }else{
      Alert.show("Login Failed !!!["+res.length+"]");
      public function loginSuccess(){
      this.logOut.label = "Log Out";
      mainView.visible = true;
      this.useridLabel.visible = false;
      this.pwdLabel.visible = false;
      this.userid.visible = false;
      this.password.visible = false;
      private function logInHandler (event:MouseEvent):void
      this.test.getUsers.send();
      private function selectionChanged (event:ListEvent):void
      var selectedItem = appList.selectedLabel;
      AppLabel.text = "Application Chosen is: '"+selectedItem+"'";
      </mx:Script>
      <mx:ApplicationControlBar dock="true" creationComplete="this.test.getUsers.send()">
      <mx:Label
      text="See-4-Cast"
      fontFamily="Verdana" fontWeight="bold" fontSize="12"
      <mx:Spacer width="100%" id="spacer01"/>
      <mx:Text id="useridLabel" text="User Id:" textAlign="right" fontWeight="bold"/>
      <mx:TextInput width="98" id="userid" maxChars="10" text="anandbn"/>
      <mx:Text id="pwdLabel" text="Password:" textAlign="right" fontWeight="bold"/>
      <mx:TextInput width="98" id="password" maxChars="10" displayAsPassword="true" text="password"/>
      <mx:Spacer width="100%" id="spacer02"/>
      <mx:Button label="Log In" id="logOut" labelPlacement="right"
      enabled="true" click="logInHandler(event)"/>
      </mx:ApplicationControlBar>
      <mx:ViewStack id="mainView" width="688" height="334" visible="false">
      <mx:TabNavigator x="10" y="10" width="100%" height="100%">
      <mx:Canvas label="Forecast Info" width="100%" height="100%">
      <mx:Label x="30" y="32" text="Choose Application:" width="119"/>
      <mx:ComboBox id="appList" enabled="true"
      left="157" top="30" change="selectionChanged(event)" selectedIndex="0">
      </mx:ComboBox>
      <mx:Label id="AppLabel" x="30" y="74" text="Application Chosen is:" width="351" height="144"/>
      <mx:Button x="340" y="30" label="Refresh"/>
      </mx:Canvas>
      <mx:Canvas label="Contractor Hours" width="100%" height="100%">
      </mx:Canvas>
      </mx:TabNavigator>
      </mx:ViewStack>
      </mx:Application>
      AS Object definitions
      package com.test
      [Managed]
      [RemoteClass(alias="com.flex.test.model.TestUser")]
      public class TestUser
      public var name:String;
      public var applications:ArrayCollection;
      package com.test
      [Managed]
      [RemoteClass(alias="com.flex.test.model.TestApplication")]
      public class TestApplication
      Java Object definitions:
      public class TestUser {
      private String name;
      private List<TestApplication> applications = new ArrayList<TestApplication>();
      public class TestApplication {
      Issue Description:
      The type of object I'm expecting is TestApplication but it shows up as "object Object". I am not sure why the object in the List is not getting converted to the correspong AS Object.
        • 1. Re: Java Collections and AS Objects
          dimival Level 1
          Ok try this, add a toString method to your TestApplication.as and run your application again, it should now who you the result of the toString method.
          What happens if you try to cast the Object to TestApplication?:
          var test:TestApplication = TestApplication(res.getItem(0));
          Alert.show(test);
          Let me know if it works
          • 2. Re: Java Collections and AS Objects
            bn_anand Level 1
            toString did not help. Here's what I have for TestApplication.as
            package com.test
            [Managed]
            public function toString():String{
            return this.name;
            Deliberate type cast to TestApplication did work but I do not want to do it that way.
            • 3. Re: Java Collections and AS Objects
              dimival Level 1
              How did you test the toString method?
              I suggest this: Alert.show(""+loggedInUser.applications[0].toString());
              You said the Casting did work but you don't want it that way? Well what do you want then?
