1. Re: Best monitors for color management
twenty_one Sep 17, 2014 7:40 AM (in response to Gary6750)There are many wide gamut monitors on the market which will natively reproduce most of Adobe RGB (I assume that's what you mean by "RGB").
But I wouldn't recommend that unless you are fully aware of the implications. Such a monitor can only be used in a fully color managed environment, and it must be calibrated and profiled to perform as intended. Without full color management there's no way it will display correctly and it's just a waste.
Taken at face value (what is the "best"), your question only has one answer: Either an NEC PA series, or an Eizo CG/CX series. They are expensive, but worth it. If you're on a tight budget, go down in size, not quality. Panel size is the single biggest cost factor and a good 24" is way better than a mediocre 27" or 30" at the same price point.
2. Re: Best monitors for color management
station_two Oct 25, 2014 1:54 PM (in response to twenty_one)twenty_one wrote:
…Taken at face value (what is the "best"), your question only has one answer: Either an NEC PA series, or an Eizo CG/CX series. They are expensive, but worth it. If you're on a tight budget, go down in size, not quality. Panel size is the single biggest cost factor and a good 24" is way better than a mediocre 27" or 30" at the same price point.
Thank you 21. It's always good to have updated information.
