3 Replies Latest reply on Apr 9, 2007 2:17 PM by kglad
    Game Creation Question
    small_guy
      Although I have a background in Flash, game creation has not been a part of it. I have been asked to apply for a Flash position that would involve some game creation. Towards this end, the company has a Flash Test to create what is (for those who really know this area) a simple sounding game. I have got the start of the effort and do not expect to be able to do the entire test. Nonetheless, I do need to add something more before I submit what I've got. (I've Googled all over for tutorials that might make sense - for me - on this. Found one (that was done in Flash MX and does not want to seem to cooperate in Pro 8).
      The gist of the game: single main character that you move with the arrow keys. Objects are randomly falling. Player intentionally moves to have the objects hit him. With each hit a score is tallied on a scoreboard until so many are hit and a message saying You've Won is displayed.
      Part of the criteria is that in the .fla file there are no objects on the stage and that this is all built into one layer and one frame. (There is more involving the creation of 3 custom classes: a game class, a man/player class and the object class. Having not created classes before - and although spent some time trying to work on that aspect of it - I am not going there.)
      I have created a movie clip of the man and a movie clip of the object. In the library I did a linkage of each. On the stage I have placed two empty movie clips, each one linked to the movie clips of the actual figures in the library. (Thus having no representations of them on the stage in the .fla.)
      I have coded the four arrow keys to move the man character about the stage.
      In light of time (of which there is none left) the only other part of the test that I would at least like to make happen is to create random copies of the object and have them randomly move.
      If anyone has any insights into this part of this it would be greatly appreciated.
      Thanks.
      Christian Seaborn
      seaborn.christian@gmail.com
        • 1. Re: Game Creation Question
          you don't need empty movieclips on stage to utilize the linkage and you'll flunk that requirement by placing two on stage.
          you can attach you man and object to the _level0 timeline. or if you like, you can use createEmptyMovieClip to create a parent movieclip to which you'll attach the man. and you can attach the object to the same empty movieclip or create a separate parent using createEmptyMovieClip again.
          you should use a loop (onEnterFrame or setInterval) to create your objects (with some randomness in time of creation and placement and movement). each object could have its own onEnterFrame loop (that's not great for efficiency but they probably aren't interested in that if they want an object class anyway and that would be easiest) to allow its own movement and to check when it's moved off-stage and should be removed and if it hits the man.
          • 2. Re: Game Creation Question
            small_guy Level 1
            Thank you for the feedback/the help. (The job is not totally about putting together games (otherwise they would not consider me at all since I have no background in that area), but it is a part of it. So thanks again for the help while I endeavor to get at least a small handle on how this part of Flash works.)
            • 3. Re: Game Creation Question
              you're welcome.
