2 Replies Latest reply on Apr 9, 2007 3:42 PM by blastbeat
    CFC Path
    blastbeat
      All,
      Curious how I change the path to my CFC's within a FLEX application. For some reason it always wants to look at my c:\inetpub\wwwroot\ instead of my \appname directory. Ideally I want c:\inetpub\wwwroot\appname\components
        • 1. Re: CFC Path
          BLXWebMaster Level 1
          If you want to put your CFC in a directory other than the webserver root, use a Coldfusion mapping. Create a mapping in CF Administrator ie; components. Reference your CFC in your Flex Apppication using dot notation ie;components.componentName. Update your services-confix.xml file and chnage the <use-mappings>true</use-mappings>. Make sure it is set to true.
          Allen
          • 2. Re: CFC Path
            blastbeat Level 1
            Allen,
            Thanks, are you sure I must make a mapping through CF? This makes hosting FLEX apps a bit more difficult don't you think? I was hoping I could simply create a directory from my application and use dot notation without the mapping in CF Admin. :(
