0 Replies Latest reply on Apr 9, 2007 10:57 AM by JimBischoff
    TileList Moving Items Up/Down
    JimBischoff
      I cannot figure out how to move items in a TileList with ActionScript. In the sample, when you run it, the moves work if the item where the selected item will be moved is being displayed, then it works as expected, but if you scroll down, and then move an item up to a spot that is not currently displayed, then the item is not selected, and sometimes the first item is deleted even though the 2 involved items are not near the first item.
      <?xml version="1.0"?>
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml"
      creationComplete = "initData();" >
      <mx:Script>
      <![CDATA[
      import mx.controls.Button;
      import mx.collections.*;
      private var listArray:Array = new Array;
      [Bindable]
      public var TileListdp:ArrayCollection;
      private function initData():void {
      var oItem:Object;
      for (var i:int = 0; i < 20; i++) {
      oItem = new Object;
      oItem.label = "Label" + i;
      oItem.data = i;
      listArray.push(oItem);
      TileListdp = new ArrayCollection(listArray);
      private function onUpClick(event:Event):void {
      var iCurSelect:int = tlList.selectedIndex;
      if (iCurSelect != -1 && iCurSelect != 0) {
      var oItem:Object = TileListdp[iCurSelect];
      TileListdp.addItemAt(oItem, iCurSelect - 1);
      TileListdp.removeItemAt(iCurSelect + 1);
      tlList.callLater(setSelection, [iCurSelect - 1]);
      private function onDownClick(event:Event):void {
      if (iCurSelect != -1 && iCurSelect != TileListdp.length) {
      TileListdp.removeItemAt(iCurSelect);
      TileListdp.addItemAt(oItem, iCurSelect + 1);
      tlList.callLater(setSelection, [iCurSelect + 1]);
      private function setSelection(iSelect:int):void {
      tlList.selectedIndex = iSelect;
      tlList.scrollToIndex(iSelect);
      </mx:Script>
      <mx:TileList
      id="tlList"
      dataProvider="{TileListdp}"
      maxColumns="2"
      height="200"
      width="200" >
      <mx:itemRenderer>
      <mx:Component>
      <mx:VBox width="100%" height="100%">
      <mx:Label width="100" text="{data.label}"/>
      <mx:Label width="100" text="{data.data}"/>
      </mx:VBox>
      </mx:Component>
      </mx:itemRenderer>
      </mx:TileList>
      <mx:Button label="Move Up" click="onUpClick(event)" />
      <mx:Button label="Move Down" click="onDownClick(event)" />
      </mx:Application>
