12 Replies Latest reply on Oct 21, 2014 4:55 PM by creativejoan0425
    GREP Problems
    creativejoan0425 Level 1
      Hi experts,
      I want to check the bracket with specific font and alert which page, but when I run the script, it cause indesign crash, it is something wrong with my script, please help me to fix it
      below is my script:
      checkBracket();
      function checkBracket(){
          app.findGrepPreferences = NothingEnum.nothing;
          app.changeGrepPreferences = NothingEnum.nothing;
          app.findChangeGrepOptions.includeFootnotes = true;
          app.findChangeGrepOptions.includeHiddenLayers = true;
          app.findChangeGrepOptions.includeLockedLayersForFind = true;
          app.findChangeGrepOptions.includeLockedStoriesForFind = true;
          app.findChangeGrepOptions.includeMasterPages = true;
          app.findChangeGrepOptions.widthSensitive = true;
          app.findGrepPreferences.findWhat="\(|\)";
          app.findGrepPreferences.appliedFont = app.fonts.item("DIN Light");
          app.findGrepPreferences.fontStyle = "Regular";
         var myList = "";
         var myfindGrep=app.findGrep();
          for(i=0; i<myfindGrep.length; i++)
              var item = myfindGrep[i];
              var page = item.parentTextFrames[0].parentPage;
              myList += page.parent.parent.name + " (Page: "+page.name +")\n";
          }//end of loop
        if (item.length>0) {
        alert("Below document(s) have wrong rounded bracket () :\n\n"+ myList +"\nPlease Global");
        }//end of if
      else {alert("no");}
      }//end of function
        • 1. Re: GREP Problems
          Peter Kahrel Adobe Community Professional & MVP
          1. If what you find is in overset text, it doesn't have any parentTextFrames, so you should guard against that:
          if (item.parentTextFrames[0] != undefined) {
          2. Use app.documents[0].findGrep() instead of app.findGrep().
          But anyway, InDesign shouldn't crash. If you can repeat the crash, file a bug report.
          Peter
          • 2. Re: GREP Problems
            Hi Peter,
            I download the pdf "Beginning ScriptUI" from you
            On page 63
            I want to alert all col2.text even col2 text has been changed (for example, I change Alpha to 1, and Bravo to 2),  but without onChanging the sbar, but I can only alert
            "1", "2", "Charlie", Delta", "Echo", "Foxtrot", Golf", "Hotel", India", "Juliet"
            How can alert all?
            var call_codes = {"A": "Alpha", "B": "Bravo", "C": "Charlie", "D": "Delta", "E": "Echo", "F": "Foxtrot", "G": "Golf", "H": "Hotel", "I": "India",
            "J": "Juliet", "K": "Kilo", "L": "Lima", "M": "Mike", "N": "November", "O": "Oscar", "P": "Papa", "Q": "Quebec", "R": "Romeo", "S": "Sierra", "T":
            "Tango", "U": "Uniform", "V": "Victor", "W": "Whiskey", "X": "X-ray", "Y": "Yankee", "Z": "Zulu"};
            var rows = 10, number_of_codes = 0;
            for (var i in call_codes) number_of_codes++; // We need to know how many elements the object contains
            var w = new Window ("dialog");
            var group = w.add ("group {alignChildren: 'fill'}");
            var panel = group.add ("panel {orientation: 'row', alignChildren: 'top'}");
            var sbar = group.add ("scrollbar {preferredSize: [20, undefined], maxvalue: " + String (number_of_codes-rows) + "}");
            var col1 = panel.add ("group {orientation: 'column', margins: 3}");
            var col2 = panel.add ("group {orientation: 'column', alignChildren: 'fill', preferredSize: [150, undefined]}");
            myText1Array =[];
            var fields = {}, start = 0, stop = rows, n = -1, myCheck = {};
            for (var i in call_codes){
            ++n;
            if (n >= start && n < stop){
            myCheck[n]  =col1.add ("statictext", [0, 0, 20, 22], i);
            fields[n] = col2.add ("edittext", undefined, call_codes[i]);
            fields[n].label = i; // Add a label property that contains the letter
            fields[n].onChange = function () {call_codes[this.label] = this.text}
            } // When the edittext is changed, update the call_codes object
            sbar.onChanging = function()
            myTextArray = [];
            var start = Math.round (this.value); // Round the sbar's value
            var stop = start+rows, n = 0, r = -1;
            n++;
            if (n > start && n <= stop)
            ++r;
            col1.children[r].text = i; // Replace the contents of the statictext
            fields[r].text = call_codes[i]; // and the edittext controls
            fields[r].label = i; // and update each edittext's label
            w.show();
            for (var i=0; i<26; i++){
            alert(col2.children[i].text);
            • 3. Re: GREP Problems
              Hello Joan,
              At the end of the script, remove these lines:
              and add these:
              for (var i in call_codes) {
                  alert (call_codes[i]);
              Peter
              On Wed, 08 Oct 2014 01:02:46 +0100, creativejoan0425
              • 4. Re: GREP Problems
                Hi Peter,
                How about these one, I open 10 documents, and each files have different total pages, at the end I want to alert all Checkbox value but I juz can alert 5 times, for the edit content I want to alert all, it can alert all but when I change the contents, the result did change
                var DocArray = app.documents.everyItem().name;
                var myPrintFiles =[];
                var myPagesLength =[];
                for (i = 0; i < DocArray.length; i++){
                                                myPrintFiles.push(app.documents.itemByName(DocArray[i]).name);
                                                myPagesLength.push(app.documents.itemByName(DocArray[i]).pages.length);
                var call_codes = {myPrintFiles: myPagesLength};
                var rows = 5, number_of_codes = DocArray.length;
                         var myPrintFilesJoin =  myPrintFiles.join("\\r");
                                    var myPrintFilesSplit =  myPrintFilesJoin.split("\\r");
                                          for (j = 0; j < myPrintFilesSplit.length; j++) {
                                                   myEachEditContent = myPrintFilesSplit[j];
                ++n;
                myCheck[n]  =col1.add ("checkbox", [0, 0, 300, 22], myPrintFilesSplit[j]);
                fields[n] = col2.add ("edittext", undefined, myPagesLength[j].toString().split(","));
                //~ for (var i in call_codes)
                n++;
                ++r;
                col1.children[r].text = myPrintFilesSplit[j]; // Replace the contents of the statictext
                fields[r].text = myPagesLength[j].toString().split(","); // and the edittext controls
                w.show();
                for (j = 0; j < 10; j++) {
                alert(myPagesLength[j].toString().split(","));
                alert(col1.children[j].value);
                Thanks and Best Regards
                Joan
                • 5. Re: GREP Problems
                  Sorry Joan, I don't see how your latest query relates to the earlier one.
                  And I really haven't a clue what you mean with "How about . . . did
                  change".
                  Peter
                  • 6. Re: GREP Problems
                    For example I open 10 indd file called 1.indd, 2.indd, 3.indd, 4.indd, 5.indd, 6.idd, 7.indd, 8.indd, 9.indd, 10.indd
                    and each file have different pages 1.indd (1 page), 2.indd (2 pages), 3.indd (3 pages), 4.indd (4 pages), 5.indd (5 pages), 6.idd (6 pages), 7.indd (7 pages), 8.indd (8 pages), 9.indd (9 pages), 10.indd (10 pages)
                    For Row1 editcontent, I change 9 to 20 and Row 2 change from 8 to 21
                    Only Row 1, 3, 5 Checkbox value is true
                    so If I alert all editcontent it should be 20, 21, 7, 6, 5, 4, 3, 2, 10, 1
                    but the result is 9, 8, 7, 6, 5, 4, 3, 2, 10,1
                    and for the Checkbox value, the result should be true, false, false, true, true, false, false, false, false, false
                    but now the result true, false, false, true, true
                    • 7. Re: GREP Problems
                      Hi Peter,
                      And I found that when I change the row 1 9 to 20 and then I use the scrollbar to scroll down and then scroll up , 20 will change back to 9, can make it when I scroll back the result is 20?
                      • 8. Re: GREP Problems
                        I'm not sure how checkboxes behave in that scrollbar method, and I can't investigate it now. If I were you I would use a simple non-scrolling list.
                        • 9. Re: GREP Problems
                          I try to use the non-scrolling list, but sometimes I need open about 40 indd files at once. so the list is too long and can't see , can the script ui dialog auto flow in other column in these case?
                          • 10. Re: GREP Problems
                            Well, you can place the list in two or three columns. No need for autoflow.
                            • 11. Re: GREP Problems
                              Thx a lots, I try
                              從三星手機發送
                              • 12. Re: GREP Problems
                                Hi Peter,
                                I cant alert all checkbox value, and editcontent even when change the text but I have a little problem, If for example checkbox 1 value is true, checkbox 2 value is false, I click the checkbox 2 , and the value become true, then I use the scrollbar , scroll down and scroll up, the result still is the first what I see, can u help me to fix it?
                                                    DocArray.sort();
                                var myCol1ValueArray = [];
                                var myCol1ValueArray1 = [];
                                                myCol1ValueArray.push("false");
                                var call_codes1 = myPrintFiles;
                                var call_codes2 = myPagesLength;
                                var rows =5, number_of_codes = 0;
                                for (var i in call_codes1) number_of_codes++; // We need to know how many elements the object contains
                                var fields = {}, start = 0, stop = rows, n = -1, myCheck = {}, m=-1;
                                for (var i in call_codes2){
                                ++n;
                                myCheck[n]  =col1.add ("checkbox", [0, 0, 300, 22], call_codes1[i]);
                                fields[n] = col2.add ("edittext", undefined, call_codes2[i]);
                                var myCol_1 = myCheck[n];
                                call_codes2[this.label] = this.text;
                                myCheckBoxText = call_codes2[i];
                                if(myCheckBoxText.toString().match(/9/)){
                                col1.children[i].value = false;
                                else{
                                col1.children[i].value = true;
                                myCol_1.value = false;
                                else{
                                myCol_1.value = true;
                                myCol1ValueArray1.push(myCol_1.value);
                                for (var i in myCol1ValueArray){
                                ++m;
                                if (m >= start && m < stop){
                                myCheck[m].label = i;
                                myCheck[m].onClick = function () {
                                    myCol1ValueArray1[this.label] = this.value;
                                sbar.onChanging = function(){
                                var stop = start+rows, n = 0, r = -1, m=0, s=-1;
                                n++;
                                if (n > start && n <= stop){
                                ++r;
                                col1.children[r].text = call_codes1[i]; // Replace the contents of the statictext
                                fields[r].text = call_codes2[i];// and the edittext controls
                                //~ alert(call_codes2[i]);
                                col1.children[r].value = false;
                                else{
                                col1.children[r].value = true;
                                myCol1ValueArray1.push(myCheck[r].value);}
                                m++;
                                if (m > start && m <= stop){
                                ++s;
                                myCheck[s].label =i;
                                myCheck[s].onClick = function () {
                                w.show();
                                alert(DocArray[i]+", "+myCol1ValueArray1[i]);
                                Many Thanks
                                Joan
