1 Reply Latest reply on Apr 9, 2007 3:43 PM by bvillanyi
    geturl() doesn't work with variable
    bvillanyi Level 1
      I have a button which does two things:
      First, it opens a new Flash movie in a new window, using the line:
      getURL("javascript:OpenBrWindow('/movie2.asp','MyMovie','status=0,scrollbars=1','865','690 ','true')");
      then it redirects the original window to a different URL using the line:
      getURL(" http://www.mydomain.com")
      This works fine when the two lines are combined in a button instance as follows:
      on (release) {
      getURL("javascript:OpenBrWindow('/movie2.asp','MyMovie','status=0,scrollbars=1','865','69 0','true')");
      But if I define a variable to contain the first url, and replace the url with the variable, the new window never opens.
      Here's the new code:
      This is set in frame 1:
      myurl = "javascript:OpenBrWindow('/movie2.asp','MyMovie','status=0,scrollbars=1','865','690','tru e')";
      This is the new code behind the button instance:
      on (release) {
      getURL(myurl);
      The second command, the redirect, works, but a new window never opens for the other movie.
      Any ideas?
      Beth
