1. Re: how to make form with round corners
Magus069 Sep 18, 2014 6:44 AM (in response to eugzl)Hi, to be able to make objects appear with round corners, obviously you need a border around the object, and in the same palette "Border" you can change the appearance of the corners...
As you see the options above Omit Border around Page Breaks, you have Corners with 4 different options. The third option is going to set the objects with round corners.
Hope this help.
2. Re: how to make form with round corners
eugzl Sep 19, 2014 6:07 AM (in response to Magus069)Hi Magus069. Thanks for replay.
I know how to make object with round corner. But how to make form page with round corner?
Thanks.
3. Re: how to make form with round corners
Magus069 Sep 19, 2014 6:30 AM (in response to eugzl)Hi, for the form page it is the same action! You need to set borders and then you can change the corners shape..
4. Re: how to make form with round corners
eugzl Sep 19, 2014 8:18 AM (in response to Magus069)I selected main subform, set round corner, and set Background Fill like Solid. But still I have behind round corner white rectangle of Master Page. What need to do to eliminate that?
Thanks.
5. Re: how to make form with round corners
Magus069 Sep 19, 2014 12:42 PM (in response to eugzl)Your TopMostSubform can have those properties too, so make sure to have the TopMostSubform set to solid edges or your main page set to solid edges...
One or the other must have solid edges..
6. Re: how to make form with round corners
eugzl Sep 20, 2014 7:36 PM (in response to Magus069)I tried to do but cannot get result. Can you attache a sample file with round corner form page shape?
Thanks.
7. Re: how to make form with round corners
radzmar Sep 21, 2014 10:42 PM (in response to eugzl)Hi,
the renderable area (bleed box) of your form is described by the medium element of your root subform.
This element doesn't support round corner I'm afraid.
