4 Replies Latest reply on Sep 20, 2014 9:46 AM by THG_BO
    Lightroom slows down at 4K Monitor
    mhierse82
      I encountered a significant slow down in normal Lightroom work (zoom in/out, rotate, develop,...)  after switching from 1920x1080 hdmi to a 4K Monitor running at 3180x2160@60Hz Displayport 1.2. What can I Do to fix this issue? Anybody else who has this problem?
        • 1. Re: Lightroom slows down at 4K Monitor
          THG_BO Level 4
          Hello,
          this is common problem with LR. Speed depends on the number of displayed pixels (computation is done on the displayed photo pixels). More pixels - less speed. There is not much you can do. You can update your CPU to a faster one. But you increased the number of pixel by >3 - you won't be able to increase CPU speed by 3. Change graphic adapter does not work for LR.
          So we all (?) in this forum wait for more speed!
          • 2. Re: Lightroom slows down at 4K Monitor
            mhierse82 Level 1
            Thank You for the fast response. I have an AMD 6core cpu at appr. 3,5 Ghz. So what would be the best upgrade option (power at value) from your experience?
            I also have a new nvidia quadro GPU for video editing - hope lightroom will use that in future releases
            • 3. Re: Lightroom slows down at 4K Monitor
              THG_BO Level 4
              Hello,
              there are a lot discussions about LR speed in this forum. Search for them, so you have lot of different meanings about this issue. My personal opinion is:
              • if you can wait, wait a few months. Adobe must fix this issus with LR6. And I expect LR6 betas in the next few month
              • rethink about your editing workflow. Do some adjustments as lens correction, upright, clarity / sharpening, extensive brush usage at last.
              • think about overclocking (in "turbo mode"). High CPU usage in LR is only for a short time. OC should not be a problem here. (Deactivte during video rendering)
              • By a cpu with the highest GHz speed in single core more. Less cores, more speed (The opposite is true for video rendering, but this can be done on GPU!)
              • 4. Re: Lightroom slows down at 4K Monitor
                THG_BO Level 4
                Hello,
                you might have a look at this thread. Lightroom 5.6 Slooow!! They report about speed improvements with LR 5.4
