2 Replies Latest reply on Sep 21, 2014 11:29 PM by pooja2087
    Export to Kindle
    aixagerendas
      I use InDesign CS6 and when I export to Kindle the TOC is empty. How can I do?
        • 1. Re: Export to Kindle
          Derek Cross Adobe Community Professional
          Does the TOC appear when you export to ePub from InDesign CS6?
          Have you tried validating the resulting ePub: http://validator.idpf.org
          How are you creating the MOBI file, are you using the InDesign to Kindle plugin?
          Is it the navigational or HTML TOC that's not appearing?
          Derek
          • 2. Re: Export to Kindle
            pooja2087 Adobe Employee
            Kindle requires a separate html file for toc and same should be referenced in guide element in content.opf. In your InDesign CS6/CC document, generate table of contents on a page and make sure the option "Make text anchor in source paragraph" is checked.
            Now export the file to EPUB 3. Open EPUB in Sigil (It is a free EPUB editor from Google). Goto Tools menu->Table of contents->Generate HTML Table of Content. This will create a new xhtml file and automatically add guide element in content.opf like this:
            <guide>
                <reference href="Text/Untitled-21.xhtml" title="Table Of Contents" type="toc" />
              </guide>
            Save EPUB and directly open in Kindle Previewer. TOC option should be enabled now and should be working.
            Please try it out and let me know if it works.
            Regards,
            Pooja
            InDesign Engineering
