1. Re: How much memory can Premiere Pro use on a new Mac Pro?
R Neil Haugen Sep 19, 2014 3:57 PM (in response to Mr. Positronic)Not a Mac expert here ... but I do know there's folks running 64G ram and so going up from 16 will work fine. Now ... as to which is the "choke-point" ... that's a bit more techie than I can answer off the bat.
The Adobe video apps can put a pretty good strain on all of the computer's hardware, and "balancing" the assets of the hardware to the usage patterns of the software is always the trick. Memory never hurts ... but if the spinning ball is a video-ram problem, changing mobo ram isn't going to do much. The various areas they go into great detail on within the pages of the "Tweakers Page" (found within these forums threads, check the hardware forum) are of course, mobo, chip/s & cores, ram, disc in-outs & arrays/layout of project/footage & program files, video card & ram.
Your problem might be best solved by more RAM; it might be that it's a disc read/write issue and either more internal or eSATA II discs to spread read/write processes over would be best ... or taking an array of discs and using a fast multi-disk RAID array to speed things up even faster, or a video card upgrade.
So ... where you might want to go is the the Hardware Forum and give your computers complete specs, including disc layout and usage, and see what folks there think needs tweaking.
Neil
