1 Reply Latest reply on Apr 11, 2007 5:56 PM by peterent
    Rotating a tab
    gauravpal
      I'm trying to create a tab bar that appears vertical. The problem is that the moment i rotate it, the text dissapears. I tried this with embedded fonts as well, but same result.
      Can anyone help?
      My files are at: http://briefcase.yahoo.com/bc/gbpal/lst?.dir=/flex
      There's a font file and a MXML file.
      -Gaurav
        • 1. Re: Rotating a tab
          peterent Level 2
          Rotation is, unfortunately, a little tricky. When you rotate something it rotates about its 0,0 point - the upper left corner. I think your text just rotated out of view. You might need to adjust its x,y position within the tab. You might need to make this one from scratch, but I've not rotated a tab before.
